🎉Community Raffle - Win $25
Join and Win
access denied (java.io.FilePermission" "<>" "execute")
User: "abhi97660"
New Altair Community Member
Updated by Jocelyn
Hello,
I am using windows os and using rapidminer 8.2
I am developing an extension in which I am trying to execute a command eg:
ffmpeg -i small.mp4
  from the java code
I have tried using
  1. Runtime.getRuntime().exec("cmd /c ffmpeg -i abc.mp4")
  2.  I have tried using process builder for the same
 but still I am getting the same error as shown in  attachment .
I have tried similar approach in simple java class program inside void main function and both the points mentioned above are working fine.
But when I tried using above mentioned points inside rapiminer extension and  I am getting the error.
I also tried using simple commands like "dir" still similar error.
I went to this Link before posting but didn't find any solution regarding this.
can anyone please provide suggestions regarding this?
1 - 4 of 41
    User: "Marco_Boeck"
    Hi,
    this is a security mechanism by RapidMiner Studio to prevent extensions from doing potentially malicious things. See https://docs.rapidminer.com/latest/developers/security/ for more details.
    Regards,
    Marco
    User: "abhi97660"
    OP
    Thanks for sharing the link I went through it.
    Also the operator called Execute Program seems to execute these commands,
    does that operator have special permissions ?
    User: "Marco_Boeck"
    Accepted Answer
    Hi,
    yes it does, because it's an operator built into Studio Core. With it, a user can do whatever he likes, but he has to enter the command himself.
    An extension however could just execute any arbitrary command without the user even knowing, which is why the restriction exists.
    Regards,
    Marco
    User: "abhi97660"
    OP
    Thank you for the suggestion my doubts regarding this are cleared.
