🎉Community Raffle - Win $25
Join and Win
Analyze 77000 tweets
User: "vittorio_confuo"
New Altair Community Member
Updated by Jocelyn
Dear community,
 I have to deal with a dataset of 77000 tweet with the following attributes: post_id, username, hash_tag, sent_time, text, user_id, source, is_retweet, is_reply, lang, retweet_count, reply_count, latitude, longitude. I must do an analysis using association rules and clustering but I'm new on RM and I hope someone can give me advice on how to proceed.
My first problem is the free license: I can read only 10000 lines. Do operators exist that generate a significant sample?
Second problem: what kind of association rules can I use? I'm thinking of "manual" sentiment analysis ( I have seen that there is Aylien extension but it has limitation and it doesn't work with italian language): is there a way to find the most important words in the tweet in order to do a positive/negative classification?
Can you suggest me some association rules and/or clustering algorithms that I could use? How could I interpret them?
I apologize for all these questions and I would be very greatful if someone wants is kind enough to help me!
Regards,
Vittorio Confuorto
1 - 20 of 201
    User: "SGolbert"
    Hi Vittorio,
    regarding the license I would suggest to request a demo. It may be a temporary solution, but it's the best to get you started and see if the platform brings value to you. You may also be able to apply for an educational license.
    https://rapidminer.com/contact-sales-request-demo/
    https://rapidminer.com/educational-program/
    Regarding the analysis, I also work with Twitter and I it's a very special case of text analysis. I think that clustering won't give you the results you want, because most of the words are just garbage and vary a lot from tweet to tweet. My suggestion would be to train a sentiment model using another dataset, and then apply it to the tweets. You have to somehow get your hands on labeled sentiment data in Italian.
    Regards,
    Sebastian
    User: "lionelderkrikor"
    Hi @vittorio_confuo,
    As mentionned Aylien has limitation, and does not support Italian.
    So I propose to use a Python script using the "textblob" library.
    This script translate the tweet from italian to english and then extract the sentiment (negative, neutral, positive) :
    -1 < sentiment < -0.1 ==> negative
    -0.1 < sentiment< 0.1 ==> neutral
    0.1< sentiment < 1 ==> positive
    The process :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.2.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34">
    <parameter key="generator_type" value="comma_separated_text"/>
    <list key="function_descriptions"/>
    <list key="numeric_series_configuration"/>
    <list key="date_series_configuration"/>
    <list key="date_series_configuration (interval)"/>
    <parameter key="input_csv_text" value="Id,Text&#10;1,iphone telefono peggiore apple ha fatto ciao messaggio&#10;"/>
    </operator>
    <operator activated="true" class="set_macros" compatibility="8.2.001" expanded="true" height="82" name="Set Macros" width="90" x="246" y="34">
    <list key="macros">
    <parameter key="textAttribute" value="'Text'"/>
    </list>
    </operator>
    <operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="380" y="34">
    <parameter key="script" value="import pandas as pd&#10;from textblob import TextBlob&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;&#10;textAttr = %{textAttribute}&#10;&#10;def translate(text):&#10;&#10; transl = TextBlob(str(text))&#10; trans = transl.translate(to = 'en') &#10; return trans&#10;&#10;def sent(text):&#10;&#10; transl = TextBlob(str(text))&#10; trans = transl.sentiment.polarity&#10; return trans&#10; &#10;&#10;def rm_main(data): &#10;&#10; data['translate'] = data[textAttr].apply(translate)&#10; data['sentiment'] = data['translate'].apply(sent)&#10; &#10; # connect 2 output ports to see the results&#10; return data"/>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="34">
    <list key="function_descriptions">
    <parameter key="Sentiment" value="if(sentiment&lt;-0.1,&quot;negative&quot;,if(sentiment&lt;0.1,&quot;neutral&quot;,&quot;positive&quot;))"/>
    </list>
    </operator>
    <connect from_op="Create ExampleSet" from_port="output" to_op="Set Macros" to_port="through 1"/>
    <connect from_op="Set Macros" from_port="through 1" to_op="Execute Python" to_port="input 1"/>
    <connect from_op="Execute Python" from_port="output 1" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    To execute this proces, you have to :
     - install python
     - install textblob (pip install textblob)
     - set your text attribute in the Set Macros parameters.
    I hope it helps
    Regards,
    Lionel
    OP
    Hi @SGolbert thank you very much. It is a good idea but actually I haven't so much time for getting by hands a dataset. If I do it (in the next week) I will post the result maybe it can be useful to someone.
    For the association rule I have thought to discretize the sent_time in order to find the most important topic for each time step (for example every hour).
    For the size of the dataset do you know if the operator "Sample stritified" is a good one?
    Thank you for your help,
    Vittorio Confuorto
    OP
    Hi @lionelderkrikor, sorry but I've just seen your answer.
    I have some problem with textblob installation. Can you tell me how to do it?
    Thank you for your time,
    Vittorio Confuorto
    User: "Thomas_Ott"
    @lionelderkrikor thank you for that awesome python script! You just gave me so many ideas for application here! I have to work with this textblob library more!
    "I have some problem with textblob installation"
    In order I can help you, can you be more precise ?
    Regards,
    Lionel
    OP
    Hi @lionelderkrikor ,
    I solved this problem but I currently have another one.
    The process return me the following error:
    Do you know how I can solve it?
    You are very kind
    Regards,
    Vittorio Confuorto
    Can you share your dataset and your process, so that I can reproduce the bug.
    Regards,
    Lionel
    Hi @Thomas_Ott,
    You're welcome,
    Happy sentiment analysis !
    Regards,
    Lionel
    User: "student_compute"
    Hello
    Can the analysis of feelings be based on the aspect?
    Thankful
    User: "Thomas_Ott"
    Hi @student_compute, I think the Textblob library can't do aspect based sentiment analysis, maybe @lionelderkrikor can confirm?
    I'm pretty sure the NLTK python library CAN do that, you'd just have to build it into RapidMiner.
    Hi all,
    yes, I confirm that the Python's library "textblob" can't do aspect based sentiment analysis.
    Regards,
    Lionel
    Hello
    Thanks for the help of dear friends
    For a NLTK sample on the rapidminer on Twitter data?
    Sorry
    Thanks a lot
    User: "SGolbert"
    Hi,
    thanks for the hint of textblob!
    I wanted also to mention the Stanford CoreNLP library:
    https://stanfordnlp.github.io/CoreNLP/index.html
    It's available both as web service and as Java library. This is surely your best option for productive use, as long as it has the required functionalities. It is a great candidate for adding functionalities to the text processing extension!
    Edit: I have seen that it does not support Italian and the .jar file is 500 mb. This limits its use as addon to the RapidMiner .jar, at least without modularization
    Best regards,
    Sebastian
    Hello. thank you very much
    I went to the site and downloaded the english file. I copied to the RapidMiner plugins. What should I do now? So I can use it to analyze aspect-based emotions?
    Thank you
    have a nice day
    Hello.
    Mr. @ lionelderkrikor
    I run your code but it has an error.
    what's wrong?
    Thanks a lot
    Hi @jozeftomas_2020,
    Here the process works fine :
    Some questions :
     - Have you sucessfully install TextBlob ?
     - Do you execute Python 2.x or Python 3.x
     - Have you modified the dataset in the parameters of the Create ExampleSet operator ?
    Can you send me back your process in order I try to reproduce your bug ?
    Regards,
    Lionel
    Hello
    My process is exactly your code
    Yes I have python and textbolb installed.
    But I do not know why it does not run.:smileymad:
    Could you check this data? Sorry sorry
    https://community.rapidminer.com/t5/RapidMiner-Studio-Forum/How-to-correct-the-wrong-words/td-p/51027/page/3
    This is the same Twitter data
    thank you very much:heart:
    Have a great day
    OK, I think I understand :
    The process in this thread is able to study the sentiment of a text which is not in English.
    Your entry dataset is already in english, so the Python script raises an error when it try to translate it in English.
    If you want study sentiment of english text (in your case tweets in english), use this process :
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <parameter key="input_csv_text" value="Id,Text&#10;1,iphone telefono peggiore apple ha fatto ciao messaggio&#10;2,iphon worst phone appl made helo meseg"/>
    </operator>
    <list key="macros">
    </list>
    </operator>
    <parameter key="script" value="import pandas as pd&#10;from textblob import TextBlob&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;&#10;textAttr = %{textAttribute}&#10;&#10;def translate(text):&#10;&#10; transl = TextBlob(str(text))&#10; trans = transl.translate(to = 'en') &#10; return trans&#10;&#10;def sent(text):&#10;&#10; transl = TextBlob(str(text))&#10; trans = transl.sentiment.polarity&#10; return trans&#10; &#10;&#10;def rm_main(data): &#10;&#10; #data['translate'] = data[textAttr].apply(sent)&#10; #data['sentiment'] = data['translate'].apply(sent)&#10; data['sentiment'] = data[textAttr].apply(sent)&#10; &#10; # connect 2 output ports to see the results&#10; return data"/>
    </operator>
    </list>
    </operator>
    </process>
    </operator>
    </process>
    I hope it helps,
    Regards,
    Lionel
    Hello
    Thank you so much for the time you spend
    And your valuable answer ..:heart:
    I will check
