How can I call an outer process from my own operator?
User: "matsuiakira"
New Altair Community Member
Updated by Jocelyn
I am concidering making my own operator, that enables me to call a UNIX command installed on my computer.
For this reason, I need to call an outer process from Java source code, but the security & restrictions have been harder scinse Rapidminer Studio 7.2.
How can I overcome the new security policy to call an outer process?
1 - 9 of 91
    Hi,
    isn't this operator already available with Execute Program?
    ~Martin
    User: "matsuiakira"
    OP
    Thanks for you quick reply, Martin!
    I know the Execute Program operator provides a similar feature,
    but what I'd like to make is one that has similar interface to Execute Python/R.
    User: "mmichel"
    Accepted Answer
    Hi,
    the execution of external applications/ commands is only possible for signed extensions.
    If you want to publish your extension on the marketplace, please write me a PM then we can speak about the signing process.
    In the meantime or for development purposes you can utilize the open core of RapidMiner Studio. Just add '-SNAPSHOT' to the RapidMiner version (gradle.properties) and the the security restrictions will not be applied.
    Next time please post these kind of questions in the development forum.
    Cheers,
    Marcel
    User: "21310122"
    After downloading the template project(rapidminer-extension-template-master) from github, there is only one line in file gradle.properties:
    version=1.0.0
    As you said, we should add -SNAPSHOT to the version of rapidminer and the the security restrictions will not be applied.
    So what's the key that stands the version of rapidminer in this properties file?
    Or I should just add -SNAPSHOT like this:
    version=1.0.0-SNAPSHOT
    User: "mmichel"
    The snapshot classifier should be added to the open-core of RapidMiner (rapidminer-studio/gradle.properties), not the extension template ;-)
    User: "21310122"
    But I don't use rapidminer-studio source code, I just add rapidminer dependency in my extension project like this image.
    So How can I edit its gradle.properties and add -SNAPSHOT?
    User: "mmichel"
    I'm afraid, but to my knowledge you would need the source code of RapidMiner Studio for that.
    User: "21310122"
    But I read your document named "how to extend RapidMiner", it said I just need use a RapidMiner as dependency like this:
    So should I add -SNAPSHOT in this dependency settings? like 7.0.0-SNAPSHOT?
    User: "mmichel"
    Nope, you should start your extension via the open core of RapidMiner Studio and add the '-SNAPSHOT' tag there (rapidminer-studio/gradle.properties).
