K-Means Clustering for Text
svtorykh
svtorykh New Altair Community Member
edited November 2024 in Community Q&A
Hi RM Team! I have a quck question about application of K-Means clustering for text.
I have a set of ~2000 comments. Once I'm done with Text Processing (using TF-IDF) I have a word vector matrix of ~30 terms.
I then apply K-means operator, but I wonder what actually serves as input for clustering? Is it vector matrix? If so, does clustering algorythm uses values from TF-IDF Word Vectors or some other values?
Welcome!
Best Answer
  • Telcontar120
    Telcontar120 New Altair Community Member
    Answer ✓
    Exactly, it is the word vector matrix that is used.  So if you created the vector using TF-IDF, it will use those values.  You also have the option of using other methods to create the vector like binary term occurrences or term frequency percentage.
Answers
  • Telcontar120
    Answer ✓
  • svtorykh
    Thanks much!
  • Telcontar120
    Your cluster will be based on the pruned values of the word vector.  If you are interested in the details you should be able to review the actual values for each cluster on the centroid table output of the k-means operator.
Welcome!
Welcome!
