Before, after, timestamp paragraph
DocMusher
DocMusher New Altair Community Member
edited November 2024 in Community Q&A
How can paragraphs be extracted from free text using different types of data-time representation?
Case:
Patient x, birth date February 5 1960
At age of 5 years, dental surgery
20/10/2012 laparoscopy with postoperative infection with pseudomonas, allergy for antibiotics without further investigation
2010 traffic accident
1976-03-10 ankle surgery
Today admitted to ICU
This text should be processed to result in a 2 columns: Text and Date
If this extraction is bulletproof, a sankey chart from a cohort of patients would be possible to be made.
Thanks
Sven
Welcome!
Answers
  • JEdward
    JEdward New Altair Community Member
    So each line becomes a text & date?
    Date | Text
    N/A | At age of 5 years, dental surgery
    20/10/2012 | laparoscopy with postoperative infection with pseudomonas, allergy for antibiotics without further investigation
    01/06/2010 | traffic accident *estimated
    1976-03-10 | ankle surgery
    now() | admitted to ICU
  • DocMusher
    Thanks for the feedback.
    In fact I need a date (sometimes calculated e.g. at 5 years should be calculated from date of birth) and a text column. The problem is that in free text a date is sometimes related to text that follows the date or vice versa.
    Is there a trick to end up with 2 colums text and date?
    Thanks
  • JEdward
    There is no simple "trick" IMO, it's going to get complex.  However, with a structured database (perhaps look into Neo4J for this?) then it should be possible.
    What you're looking to do is build relationships between date stamped text entities with other date stamped text entities.
    Then using those date stamped text entities to help guide extraction of new date stamped text entities from text containing dates.
  • BalazsBaranyRM
    BalazsBaranyRM New Altair Community Member
    Hi,
    your best guess is using a list of rules from experience in Generate Attributes. For example:
    if(matches(text, "^ *([0-9]{4}-[0-9][0-9]?-[0-9][0-9]?) .*"),
    date_parse_custom(replaceAll(text, "^ *([0-9-]+).*", "$1"), "yyyy-MM-dd", "en"),
    if(matches(text, "^ *([0-9][0-9]?/[0-9][0-9]?/[0-9]{4}) .*"),
    date_parse_custom(replaceAll(text, "^ *([0-9/]+).*", "$1"), "dd/MM/yyyy", "en"),
    if(matches(lower(text), "^ *(today|now).*"),
    date_now(),
    MISSING_DATE
    This catches three of the dates in your input and is already becoming hard to read. You could always get conversion errors from stuff like 33/11/2017 and so on, so it would be best to apply this line for line in an exception handler.
    You might want to try using a library like lubridate in R to more easily convert the date string candidates you identified in the text.
    But it will be a mess anyway, I wish you good luck.
    Regards,
    Balázs
  • JEdward
    @BalazsBarany the date extraction part is one of the more easiest parts.  It's the link between those dates where it becomes more tricky.  (Which is why I suggested a graph database)
    Here's an example of a process that I use for date extraction from text, where the date could be in multiple formats.
    https://community.rapidminer.com/t5/Original-Rapid-I-Forum/Extracting-date-from-textfiles/m-p/30203
    You could use this with the addition of predictive model learned on the historically captured text data to add context such as "5 years old = dateofbirth + 5 years
  • sgenzer
    sgenzer
    Altair Employee
    there's probably some good fuzzy matching solution to this...it would be very nice if RapidMiner had some fancy algorithms in some kind of data prep wizard to do that for us, eh? Just sayin', @IngoRM...  :)
    Meanwhile I actually was doing something similar a year or so ago - trying to parse out dates from newspaper death notices. Here is the block I created (it's a complete mess but maybe something inside is useful for you? It's a 100% brute force solution)
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="124" name="DateOfObit" width="90" x="45" y="34">
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="generate DateOfObitRAW" width="90" x="45" y="340">
    <operator activated="true" class="multiply" compatibility="8.2.000" expanded="true" height="103" name="Multiply (23)" width="90" x="45" y="85"/>
    <operator activated="true" class="generate_id" compatibility="8.2.000" expanded="true" height="82" name="Generate ID (42)" width="90" x="179" y="442"/>
    <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Slice DateOfObitRAW" width="90" x="246" y="34">
    <parameter key="create_word_vector" value="false"/>
    <parameter key="add_meta_information" value="false"/>
    <parameter key="keep_text" value="true"/>
    <parameter key="select_attributes_and_weights" value="true"/>
    <list key="specify_weights">
    <parameter key="att1" value="1.0"/>
    </list>
    <operator activated="true" class="text:keep_document_parts" compatibility="7.5.000" expanded="true" height="68" name="DateOfObit Regex" width="90" x="313" y="34">
    <parameter key="extraction_regex" value="\s\w+\W+[0-9]+\W+1[0-9]+"/>
    </operator>
    <connect from_port="document" to_op="DateOfObit Regex" to_port="document"/>
    <connect from_op="DateOfObit Regex" from_port="document" to_port="document 1"/>
    <portSpacing port="source_document" spacing="0"/>
    <portSpacing port="sink_document 1" spacing="0"/>
    <portSpacing port="sink_document 2" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="generate_id" compatibility="8.2.000" expanded="true" height="82" name="Generate ID (43)" width="90" x="380" y="34"/>
    <operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role (17)" width="90" x="514" y="34">
    <parameter key="attribute_name" value="text"/>
    <list key="set_additional_roles"/>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (74)" width="90" x="648" y="34">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="text"/>
    </operator>
    <operator activated="true" class="join" compatibility="8.2.000" expanded="true" height="82" name="Join (32)" width="90" x="782" y="391">
    <list key="key_attributes"/>
    </operator>
    <operator activated="true" class="trim" compatibility="8.2.000" expanded="true" height="82" name="Trim (35)" width="90" x="916" y="136"/>
    <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename (55)" width="90" x="1050" y="136">
    <parameter key="old_name" value="text"/>
    <parameter key="new_name" value="DateOfObitRAW"/>
    <list key="rename_additional_attributes"/>
    </operator>
    <operator activated="true" class="text_to_nominal" compatibility="8.2.000" expanded="true" height="82" name="Text to Nominal (4)" width="90" x="1184" y="136"/>
    <operator activated="true" class="replace" compatibility="8.2.000" expanded="true" height="82" name="Replace (80)" width="90" x="1318" y="136">
    <parameter key="attribute" value="DateOfObitRAW"/>
    <parameter key="replace_what" value=","/>
    <description align="center" color="transparent" colored="false" width="126">get rid of commas</description>
    </operator>
    <connect from_port="in 1" to_op="Multiply (23)" to_port="input"/>
    <connect from_op="Multiply (23)" from_port="output 1" to_op="Slice DateOfObitRAW" to_port="example set"/>
    <connect from_op="Multiply (23)" from_port="output 2" to_op="Generate ID (42)" to_port="example set input"/>
    <connect from_op="Generate ID (42)" from_port="example set output" to_op="Join (32)" to_port="right"/>
    <connect from_op="Slice DateOfObitRAW" from_port="example set" to_op="Generate ID (43)" to_port="example set input"/>
    <connect from_op="Generate ID (43)" from_port="example set output" to_op="Set Role (17)" to_port="example set input"/>
    <connect from_op="Set Role (17)" from_port="example set output" to_op="Select Attributes (74)" to_port="example set input"/>
    <connect from_op="Select Attributes (74)" from_port="example set output" to_op="Join (32)" to_port="left"/>
    <connect from_op="Join (32)" from_port="join" to_op="Trim (35)" to_port="example set input"/>
    <connect from_op="Trim (35)" from_port="example set output" to_op="Rename (55)" to_port="example set input"/>
    <connect from_op="Rename (55)" from_port="example set output" to_op="Text to Nominal (4)" to_port="example set input"/>
    <connect from_op="Text to Nominal (4)" from_port="example set output" to_op="Replace (80)" to_port="example set input"/>
    <connect from_op="Replace (80)" from_port="example set output" to_port="out 1"/>
    <portSpacing port="source_in 1" spacing="0"/>
    <portSpacing port="source_in 2" spacing="0"/>
    <portSpacing port="sink_out 1" spacing="0"/>
    <portSpacing port="sink_out 2" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">generate DateOfObitRAW</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (59)" width="90" x="179" y="340">
    <parameter key="parameter_expression" value="finds(att1,&quot;.*[0-9].*&quot;)"/>
    <parameter key="condition_class" value="expression"/>
    <list key="filters_list"/>
    <description align="center" color="transparent" colored="false" width="126">contains a number (likely contains a date of obit)</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (60)" width="90" x="313" y="34">
    <list key="filters_list">
    <parameter key="filters_entry_key" value="DateOfObitRAW.is_not_missing."/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">DateOfObitRAW is not missing</description>
    </operator>
    <operator activated="true" breakpoints="after" class="subprocess" compatibility="8.2.000" expanded="true" height="124" name="fix wonky DateOfObitRAW records" width="90" x="514" y="136">
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (95)" width="90" x="45" y="34">
    <parameter key="invert_selection" value="true"/>
    <description align="center" color="transparent" colored="false" width="126">get rid of DateOfObitRAW</description>
    </operator>
    <operator activated="true" class="generate_copy" compatibility="8.2.000" expanded="true" height="82" name="Generate Copy (12)" width="90" x="179" y="34">
    <parameter key="attribute_name" value="att1"/>
    <description align="center" color="transparent" colored="false" width="126">copy att1 to DateOfObitRAW</description>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="Subprocess (187)" width="90" x="313" y="34">
    <operator activated="true" class="multiply" compatibility="8.2.000" expanded="true" height="103" name="Multiply (29)" width="90" x="45" y="34"/>
    <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data (8)" width="90" x="246" y="34">
    <parameter key="DateOfObitRAW" value="1.0"/>
    </list>
    <operator activated="false" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts" width="90" x="112" y="34">
    <parameter key="deletion_regex" value="[A-Za-z][a-z]+[-,]"/>
    <description align="center" color="transparent" colored="false" width="126">word with comma at end</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (2)" width="90" x="246" y="34">
    <parameter key="deletion_regex" value="[A-Z][-.]"/>
    <description align="center" color="transparent" colored="false" width="126">middle initials</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (3)" width="90" x="380" y="34">
    <parameter key="deletion_regex" value="[BCEGHIKLPQRTUVWXYZ][a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">words starting with any letter than is not a month letter</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (4)" width="90" x="514" y="34">
    <parameter key="deletion_regex" value="\s[a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">any word that does not start with a capital letter</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (6)" width="90" x="648" y="34">
    <parameter key="deletion_regex" value="A[^up][a-z]+|Au[^g][a-z]+|Ap[^r][a-z]+|August[a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with A that are not Aug or Apr</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (5)" width="90" x="782" y="34">
    <parameter key="deletion_regex" value="M[^a][a-z]+|Ma[^ry][a-z]+|Mar[^c][a-z]+|Mary"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with M that are not May or March</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (7)" width="90" x="916" y="34">
    <parameter key="deletion_regex" value="F[^e][a-z]+|Fe[^b][a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with F that are not Feb</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (8)" width="90" x="1050" y="34">
    <parameter key="deletion_regex" value="N[^o][a-z]+|No[^v][a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with N that are not Nov</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (9)" width="90" x="1184" y="34">
    <parameter key="deletion_regex" value="D[^e][a-z]+|De[^c][a-z]+|Dec[^e][a-z]+|De[^c]\s"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with D that are not Dec</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (10)" width="90" x="1318" y="34">
    <parameter key="deletion_regex" value="S[^e][a-z]+|Se[^p][a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with S that are not Sep</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (11)" width="90" x="1452" y="34">
    <parameter key="deletion_regex" value="J[^au][a-z]+|Ja[^n][a-z]+|Jan[^u][a-z]+|Ju[^ln][a-z]+|Ja[^n][a-z]+|Jul[^y][a-z]+|Ja[^n]|Jane"/>
    <description align="center" color="transparent" colored="false" width="126">Words that start with J that are not Jun or Jul or Jan</description>
    </operator>
    <operator activated="true" class="text:remove_document_parts" compatibility="7.5.000" expanded="true" height="68" name="Remove Document Parts (12)" width="90" x="1586" y="34">
    <parameter key="deletion_regex" value="[A-Z]\W+|[A-Z][a-z]\W+|[0-9][a-z]\W|th|\W[a-z]+"/>
    <description align="center" color="transparent" colored="false" width="126">Single letters followed by non-word chars</description>
    </operator>
    <connect from_port="document" to_op="Remove Document Parts (2)" to_port="document"/>
    <connect from_op="Remove Document Parts (2)" from_port="document" to_op="Remove Document Parts (3)" to_port="document"/>
    <connect from_op="Remove Document Parts (3)" from_port="document" to_op="Remove Document Parts (4)" to_port="document"/>
    <connect from_op="Remove Document Parts (4)" from_port="document" to_op="Remove Document Parts (6)" to_port="document"/>
    <connect from_op="Remove Document Parts (6)" from_port="document" to_op="Remove Document Parts (5)" to_port="document"/>
    <connect from_op="Remove Document Parts (5)" from_port="document" to_op="Remove Document Parts (7)" to_port="document"/>
    <connect from_op="Remove Document Parts (7)" from_port="document" to_op="Remove Document Parts (8)" to_port="document"/>
    <connect from_op="Remove Document Parts (8)" from_port="document" to_op="Remove Document Parts (9)" to_port="document"/>
    <connect from_op="Remove Document Parts (9)" from_port="document" to_op="Remove Document Parts (10)" to_port="document"/>
    <connect from_op="Remove Document Parts (10)" from_port="document" to_op="Remove Document Parts (11)" to_port="document"/>
    <connect from_op="Remove Document Parts (11)" from_port="document" to_op="Remove Document Parts (12)" to_port="document"/>
    <connect from_op="Remove Document Parts (12)" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="generate_id" compatibility="8.2.000" expanded="true" height="82" name="Generate ID (50)" width="90" x="246" y="136"/>
    <operator activated="true" class="generate_id" compatibility="8.2.000" expanded="true" height="82" name="Generate ID (51)" width="90" x="380" y="34"/>
    <operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role (20)" width="90" x="514" y="34">
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (96)" width="90" x="648" y="34">
    </operator>
    <operator activated="true" class="join" compatibility="8.2.000" expanded="true" height="82" name="Join (37)" width="90" x="782" y="85">
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (97)" width="90" x="916" y="85">
    </operator>
    <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename (76)" width="90" x="1050" y="85">
    </operator>
    <operator activated="true" class="trim" compatibility="8.2.000" expanded="true" height="82" name="Trim (49)" width="90" x="1184" y="85"/>
    <connect from_port="in 1" to_op="Multiply (29)" to_port="input"/>
    <connect from_op="Multiply (29)" from_port="output 1" to_op="Process Documents from Data (8)" to_port="example set"/>
    <connect from_op="Multiply (29)" from_port="output 2" to_op="Generate ID (50)" to_port="example set input"/>
    <connect from_op="Process Documents from Data (8)" from_port="example set" to_op="Generate ID (51)" to_port="example set input"/>
    <connect from_op="Generate ID (50)" from_port="example set output" to_op="Join (37)" to_port="right"/>
    <connect from_op="Generate ID (51)" from_port="example set output" to_op="Set Role (20)" to_port="example set input"/>
    <connect from_op="Set Role (20)" from_port="example set output" to_op="Select Attributes (96)" to_port="example set input"/>
    <connect from_op="Select Attributes (96)" from_port="example set output" to_op="Join (37)" to_port="left"/>
    <connect from_op="Join (37)" from_port="join" to_op="Select Attributes (97)" to_port="example set input"/>
    <connect from_op="Select Attributes (97)" from_port="example set output" to_op="Rename (76)" to_port="example set input"/>
    <connect from_op="Rename (76)" from_port="example set output" to_op="Trim (49)" to_port="example set input"/>
    <connect from_op="Trim (49)" from_port="example set output" to_port="out 1"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">1ST TRY</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (61)" width="90" x="447" y="289">
    <parameter key="parameter_expression" value="!finds(DateOfObitRAW,&quot;[-.,?/]&quot;)"/>
    <description align="center" color="transparent" colored="false" width="126">no punctuation</description>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="small punctuation fixes" width="90" x="581" y="340">
    <operator activated="true" class="trim" compatibility="8.2.000" expanded="true" height="82" name="Trim (50)" width="90" x="45" y="34">
    </operator>
    <operator activated="true" class="replace" compatibility="8.2.000" expanded="true" height="82" name="Replace (105)" width="90" x="179" y="34">
    <parameter key="replace_what" value="[()]|[.]\s+"/>
    <parameter key="replace_by" value=" "/>
    </operator>
    <operator activated="true" class="replace" compatibility="8.2.000" expanded="true" height="82" name="Replace (106)" width="90" x="313" y="34">
    <parameter key="replace_what" value="[-,]\s|\s\s+"/>
    </operator>
    <operator activated="true" class="trim" compatibility="8.2.000" expanded="true" height="82" name="Trim (51)" width="90" x="447" y="34">
    </operator>
    <connect from_port="in 1" to_op="Trim (50)" to_port="example set input"/>
    <connect from_op="Trim (50)" from_port="example set output" to_op="Replace (105)" to_port="example set input"/>
    <connect from_op="Replace (105)" from_port="example set output" to_op="Replace (106)" to_port="example set input"/>
    <connect from_op="Replace (106)" from_port="example set output" to_op="Trim (51)" to_port="example set input"/>
    <connect from_op="Trim (51)" from_port="example set output" to_port="out 1"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">small punctuation fixes</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (63)" width="90" x="715" y="340">
    <parameter key="parameter_expression" value="finds(prefix(DateOfObitRAW,1),&quot;[A-Z]&quot;)"/>
    <description align="center" color="transparent" colored="false" width="126">starts with a capital letter</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (62)" width="90" x="581" y="136">
    <parameter key="filters_entry_key" value="DateOfObitRAW.starts_with.1"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">starts with a number (year only)</description>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (145)" width="90" x="715" y="34">
    <list key="function_descriptions">
    <parameter key="YearOfObit" value="DateOfObitRAW"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">YearOfObit</description>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (99)" width="90" x="849" y="34">
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (146)" width="90" x="715" y="187">
    <parameter key="YearOfObit" value="suffix(DateOfObitRAW,4)"/>
    </list>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="Subprocess (188)" width="90" x="849" y="187">
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (147)" width="90" x="45" y="34">
    <parameter key="MonthOfObit" value="prefix(DateOfObitRAW,index(DateOfObitRAW,&quot; &quot;))"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">MonthOfObit</description>
    </operator>
    <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve month lookup (4)" width="90" x="45" y="187">
    <parameter key="repository_entry" value="month lookup"/>
    </operator>
    <operator activated="true" class="join" compatibility="8.2.000" expanded="true" height="82" name="Join (38)" width="90" x="179" y="34">
    <parameter key="join_type" value="left"/>
    <parameter key="use_id_attribute_as_key" value="false"/>
    <list key="key_attributes">
    <parameter key="MonthOfObit" value="MonthRAW"/>
    </list>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (98)" width="90" x="313" y="34">
    <parameter key="attribute" value="MonthOfObit"/>
    </operator>
    <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename (77)" width="90" x="447" y="34">
    <parameter key="old_name" value="MonthMMM"/>
    <parameter key="new_name" value="MonthOfObit"/>
    </operator>
    <connect from_port="in 1" to_op="Generate Attributes (147)" to_port="example set input"/>
    <connect from_op="Generate Attributes (147)" from_port="example set output" to_op="Join (38)" to_port="left"/>
    <connect from_op="Retrieve month lookup (4)" from_port="output" to_op="Join (38)" to_port="right"/>
    <connect from_op="Join (38)" from_port="join" to_op="Select Attributes (98)" to_port="example set input"/>
    <connect from_op="Select Attributes (98)" from_port="example set output" to_op="Rename (77)" to_port="example set input"/>
    <connect from_op="Rename (77)" from_port="example set output" to_port="out 1"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">parse out MonthOfObit</description>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (148)" width="90" x="983" y="187">
    <parameter key="DayOfObit" value="cut(DateOfObitRAW,index(DateOfObitRAW,&quot; &quot;)+1,2)"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">DayOfObit</description>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (100)" width="90" x="1117" y="187">
    </operator>
    <operator activated="true" class="union" compatibility="8.2.000" expanded="true" height="82" name="Union (55)" width="90" x="1251" y="34"/>
    <connect from_port="in 1" to_op="Select Attributes (95)" to_port="example set input"/>
    <connect from_op="Select Attributes (95)" from_port="example set output" to_op="Generate Copy (12)" to_port="example set input"/>
    <connect from_op="Generate Copy (12)" from_port="example set output" to_op="Subprocess (187)" to_port="in 1"/>
    <connect from_op="Subprocess (187)" from_port="out 1" to_op="Filter Examples (61)" to_port="example set input"/>
    <connect from_op="Filter Examples (61)" from_port="example set output" to_op="Filter Examples (62)" to_port="example set input"/>
    <connect from_op="Filter Examples (61)" from_port="unmatched example set" to_op="small punctuation fixes" to_port="in 1"/>
    <connect from_op="small punctuation fixes" from_port="out 1" to_op="Filter Examples (63)" to_port="example set input"/>
    <connect from_op="Filter Examples (63)" from_port="example set output" to_port="out 2"/>
    <connect from_op="Filter Examples (63)" from_port="unmatched example set" to_port="out 3"/>
    <connect from_op="Filter Examples (62)" from_port="example set output" to_op="Generate Attributes (145)" to_port="example set input"/>
    <connect from_op="Filter Examples (62)" from_port="unmatched example set" to_op="Generate Attributes (146)" to_port="example set input"/>
    <connect from_op="Generate Attributes (145)" from_port="example set output" to_op="Select Attributes (99)" to_port="example set input"/>
    <connect from_op="Select Attributes (99)" from_port="example set output" to_op="Union (55)" to_port="example set 1"/>
    <connect from_op="Generate Attributes (146)" from_port="example set output" to_op="Subprocess (188)" to_port="in 1"/>
    <connect from_op="Subprocess (188)" from_port="out 1" to_op="Generate Attributes (148)" to_port="example set input"/>
    <connect from_op="Generate Attributes (148)" from_port="example set output" to_op="Select Attributes (100)" to_port="example set input"/>
    <connect from_op="Select Attributes (100)" from_port="example set output" to_op="Union (55)" to_port="example set 2"/>
    <connect from_op="Union (55)" from_port="union" to_port="out 1"/>
    <portSpacing port="sink_out 3" spacing="0"/>
    <portSpacing port="sink_out 4" spacing="0"/>
    <description align="center" color="yellow" colored="false" height="50" resized="false" width="119" x="1362" y="39">CLEAN</description>
    </process>
    </operator>
    <operator activated="true" class="append" compatibility="8.2.000" expanded="true" height="103" name="Append (8)" width="90" x="715" y="34"/>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="Subprocess (191)" width="90" x="849" y="34">
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (111)" width="90" x="45" y="34">
    </list>
    </operator>
    <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve month lookup (3)" width="90" x="45" y="187">
    </operator>
    <operator activated="true" class="join" compatibility="8.2.000" expanded="true" height="82" name="Join (33)" width="90" x="179" y="34">
    </list>
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (75)" width="90" x="313" y="34">
    </operator>
    <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename (56)" width="90" x="447" y="34">
    </operator>
    <connect from_port="in 1" to_op="Generate Attributes (111)" to_port="example set input"/>
    <connect from_op="Generate Attributes (111)" from_port="example set output" to_op="Join (33)" to_port="left"/>
    <connect from_op="Retrieve month lookup (3)" from_port="output" to_op="Join (33)" to_port="right"/>
    <connect from_op="Join (33)" from_port="join" to_op="Select Attributes (75)" to_port="example set input"/>
    <connect from_op="Select Attributes (75)" from_port="example set output" to_op="Rename (56)" to_port="example set input"/>
    <connect from_op="Rename (56)" from_port="example set output" to_port="out 1"/>
    </process>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (112)" width="90" x="983" y="34">
    </list>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="Subprocess (192)" width="90" x="1117" y="34">
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (113)" width="90" x="45" y="34">
    </list>
    </operator>
    <operator activated="true" class="replace" compatibility="8.2.000" expanded="true" height="82" name="Replace (81)" width="90" x="179" y="34">
    <parameter key="attribute" value="YearOfObit"/>
    <parameter key="replace_what" value="[--]|\s"/>
    <description align="center" color="transparent" colored="false" width="126">get rid of space and dash in YearOfObit</description>
    </operator>
    <operator activated="true" class="declare_missing_value" compatibility="7.1.001" expanded="true" height="82" name="Declare Missing Value (58)" width="90" x="313" y="34">
    <parameter key="mode" value="expression"/>
    <parameter key="expression_value" value="length(YearOfObit)&lt;4"/>
    <description align="center" color="transparent" colored="false" width="126">get rid of YearOfObit with length &amp;lt;4</description>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (114)" width="90" x="447" y="34">
    <parameter key="YearOfObit" value="if(prefix(YearOfObit,2)==&quot;10&quot;,concat(&quot;19&quot;,suffix(YearOfObit,2)),YearOfObit)"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">fix year 10xx</description>
    </operator>
    <connect from_port="in 1" to_op="Generate Attributes (113)" to_port="example set input"/>
    <connect from_op="Generate Attributes (113)" from_port="example set output" to_op="Replace (81)" to_port="example set input"/>
    <connect from_op="Replace (81)" from_port="example set output" to_op="Declare Missing Value (58)" to_port="example set input"/>
    <connect from_op="Declare Missing Value (58)" from_port="example set output" to_op="Generate Attributes (114)" to_port="example set input"/>
    <connect from_op="Generate Attributes (114)" from_port="example set output" to_port="out 1"/>
    </process>
    </operator>
    <operator activated="true" class="subprocess" compatibility="8.2.000" expanded="true" height="82" name="Subprocess (193)" width="90" x="1251" y="34">
    <operator activated="true" class="trim" compatibility="8.2.000" expanded="true" height="82" name="Trim (36)" width="90" x="45" y="136"/>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples (46)" width="90" x="179" y="136">
    <parameter key="filters_entry_key" value="YearOfObit.is_not_missing."/>
    <parameter key="filters_entry_key" value="MonthOfObit.is_not_missing."/>
    <parameter key="filters_entry_key" value="DayOfObit.is_not_missing."/>
    <parameter key="filters_entry_key" value="DayOfObit.does_not_contain.?"/>
    <parameter key="filters_entry_key" value="DayOfObit.does_not_contain.-"/>
    <parameter key="filters_entry_key" value="DayOfObit.does_not_contain.\."/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">day, month and year of obit are not missing</description>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (115)" width="90" x="313" y="34">
    <parameter key="DateOfObitPARSE" value="date_parse(concat(MonthOfObit,&quot;/&quot;,DayOfObit,&quot;/&quot;,YearOfObit))"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">create DateOfObitPARSE</description>
    </operator>
    <operator activated="true" class="date_to_nominal" compatibility="8.1.002" expanded="true" height="82" name="Date to Nominal (4)" width="90" x="447" y="34">
    <parameter key="attribute_name" value="DateOfObitPARSE"/>
    <parameter key="date_format" value="MMM dd, yyyy"/>
    <parameter key="time_zone" value="SYSTEM"/>
    </operator>
    <operator activated="true" class="nominal_to_date" compatibility="8.2.000" expanded="true" height="82" name="Nominal to Date (4)" width="90" x="581" y="34">
    </operator>
    <operator activated="true" class="union" compatibility="8.2.000" expanded="true" height="82" name="Union (41)" width="90" x="715" y="187"/>
    <connect from_port="in 1" to_op="Trim (36)" to_port="example set input"/>
    <connect from_op="Trim (36)" from_port="example set output" to_op="Filter Examples (46)" to_port="example set input"/>
    <connect from_op="Filter Examples (46)" from_port="example set output" to_op="Generate Attributes (115)" to_port="example set input"/>
    <connect from_op="Filter Examples (46)" from_port="unmatched example set" to_op="Union (41)" to_port="example set 2"/>
    <connect from_op="Generate Attributes (115)" from_port="example set output" to_op="Date to Nominal (4)" to_port="example set input"/>
    <connect from_op="Date to Nominal (4)" from_port="example set output" to_op="Nominal to Date (4)" to_port="example set input"/>
    <connect from_op="Nominal to Date (4)" from_port="example set output" to_op="Union (41)" to_port="example set 1"/>
    <connect from_op="Union (41)" from_port="union" to_port="out 1"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">DateOfObitPARSE</description>
    </operator>
    <operator activated="true" class="append" compatibility="8.2.000" expanded="true" height="103" name="Append (7)" width="90" x="1318" y="391"/>
    <connect from_port="in 1" to_op="generate DateOfObitRAW" to_port="in 1"/>
    <connect from_op="generate DateOfObitRAW" from_port="out 1" to_op="Filter Examples (59)" to_port="example set input"/>
    <connect from_op="Filter Examples (59)" from_port="example set output" to_op="Filter Examples (60)" to_port="example set input"/>
    <connect from_op="Filter Examples (59)" from_port="unmatched example set" to_op="Append (7)" to_port="example set 2"/>
    <connect from_op="Filter Examples (60)" from_port="example set output" to_op="Append (8)" to_port="example set 1"/>
    <connect from_op="Filter Examples (60)" from_port="unmatched example set" to_op="fix wonky DateOfObitRAW records" to_port="in 1"/>
    <connect from_op="fix wonky DateOfObitRAW records" from_port="out 1" to_op="Append (8)" to_port="example set 2"/>
    <connect from_op="fix wonky DateOfObitRAW records" from_port="out 2" to_port="out 2"/>
    <connect from_op="fix wonky DateOfObitRAW records" from_port="out 3" to_port="out 3"/>
    <connect from_op="Append (8)" from_port="merged set" to_op="Subprocess (191)" to_port="in 1"/>
    <connect from_op="Subprocess (191)" from_port="out 1" to_op="Generate Attributes (112)" to_port="example set input"/>
    <connect from_op="Generate Attributes (112)" from_port="example set output" to_op="Subprocess (192)" to_port="in 1"/>
    <connect from_op="Subprocess (192)" from_port="out 1" to_op="Subprocess (193)" to_port="in 1"/>
    <connect from_op="Subprocess (193)" from_port="out 1" to_op="Append (7)" to_port="example set 1"/>
    <connect from_op="Append (7)" from_port="merged set" to_port="out 1"/>
    <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="674" y="156">delete me!!</description>
    <description align="center" color="yellow" colored="false" height="69" resized="false" width="126" x="835" y="112">fix missing DateOfObitRAW records</description>
    <description align="center" color="yellow" colored="false" height="50" resized="false" width="126" x="844" y="262">parse out MonthOfObit</description>
    </process>
    <description align="center" color="transparent" colored="false" width="126">DateOfObit</description>
    </operator>
    </process>
    </operator>
    </process>
    Scott
Welcome!
Welcome!
