🎉Community Raffle - Win $25
Join and Win
Weka Extension W-Logistic Regression Operator - Weka Results tab doesn't produce any output ???
User: "lanem"
New Altair Community Member
Updated by Jocelyn
Hi
Description Tab works fine provides the Logistic Regression Coefficients and Odds Ratios for the Coefficients but Weka Results Tab doesn't produce any result
I demonstrate this using the North Textbook Data Mining for Masses Chapter 9 Logistic Regression data sets and two screen captures of relevant outputs in RapidMiner
Any advice on this - is this simply a bug in the Weka Extension Logistic Regression operator in RapidMiner???
or is there someway to get the output Weka Result Tab
Regards Michael
1 - 2 of 21
    User: "Telcontar120"
    Accepted Answer
    Looks like another Weka operator bug to me.  There are reports of several of them at this point, I hope someone is able to take a look at that extension in the near future, it really has a lot of helpful algorithms that there are not native RapidMiner operators for!  Fortunately, in this case the recently overhauled native Logistic Regression operator (actually coming from H20.ai) is a pretty good substitute.
    User: "lanem"
    OP
    Accepted Answer
    Hi
    Many thanks yes I am using the standard logistic regression operator now available in RapidMiner provides a lot of useful information only thing it does not calculate the odds ratio for each coefficient
    but that is easily calculated in either in a Excel Spreadsheet or in RapidMiner using exp function with abs function nested inside for instance exp(abs(coeff-value)) etc
    it would be good to see RapidMiner implement this missing statistical value and also the risk ratio would be even better
    cheers Michael RapidMiner overall rocks!!!
