🎉Community Raffle - Win $25
Join and Win
Text Mining Words not produced
asn4293User: "asn4293"
New Altair Community Member
Updated by Jocelyn
So I have to find the number of specific words occurences in the excel file. For example I have ten columns in which it have in each row we have one employee. Each employee profile may contain one word which we want to find with number of occurences.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="187">
<parameter key="excel_file" value="C:\Users\shahida1\Desktop\Sample Testing Text Mining.xlsx"/>
<parameter key="imported_cell_range" value="A1:F36"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="User Sys ID.true.integer.id"/>
<parameter key="1" value="Employee Id.true.integer.attribute"/>
<parameter key="2" value="Last name.true.polynominal.attribute"/>
<parameter key="3" value="First name.true.polynominal.attribute"/>
<parameter key="4" value="Business Unit.true.polynominal.attribute"/>
<parameter key="5" value="Functional Area.true.polynominal.attribute"/>
</list>
</operator>
<operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="246" y="187">
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights"/>
</operator>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="447" y="187">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="238"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="313" y="238"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="112" y="442">
<parameter key="sheet_number" value="2"/>
<parameter key="imported_cell_range" value="A1:A2"/>
</list>
<parameter key="0" value="Matching Text.true.polynominal.attribute"/>
</list>
</operator>
<operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="442">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="Matching Text"/>
</operator>
<operator activated="true" class="operator_toolbox:filter_tokens_using_exampleset" compatibility="1.0.000" expanded="true" height="82" name="Filter Tokens Using ExampleSet" width="90" x="581" y="340"/>
<connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Filter Tokens Using ExampleSet" to_port="example set"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Tokens Using ExampleSet" to_port="document"/>
<connect from_op="Filter Tokens Using ExampleSet" from_port="document" to_port="result 1"/>
</process>
</operator>
</process>
This is the file which I am working on.
https://drive.google.com/open?id=1PT38TyBmoIHDfIVCAk7Je3l3AXRP-4Gi
1 - 5 of 51
    Hi @asn4293,
    1. Can you verify your process, the XML you sent is broken.
    2. In your Excel file extract, there is only one occurence of the key word ("sales, "supply", "logistics" etc.) in each employee caracteristics .
    So what do you want to perform ?
     - Calculate the number of occurence of the keyword for each employee (so it will be always 1 in your extract)
     - Calculate the number of occurence of the keyword in the whole file ?
     - An other task ....????
    Regards,
    Lionel
    Hi @asn4293,
    Here a process to count the occurence of the keywordv in the whole file (if you want the number of occurence for each employee, remove/disable the Aggregate operator).
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
    <operator activated="true" breakpoints="after" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Count_Keyword\Sample Testing Text Mining.xlsx"/>
    </list>
    <parameter key="0" value="User Sys ID.true.integer.attribute"/>
    <parameter key="5" value="Functional Area.true.text.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel (2)" width="90" x="45" y="187">
    </list>
    <parameter key="0" value="Matching Text.true.text.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="179" y="187">
    <parameter key="keep_text" value="true"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="246" y="34"/>
    <connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
    <connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="380" y="34">
    <parameter key="vector_creation" value="Term Occurrences"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34"/>
    <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="380" y="34"/>
    <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
    </process>
    </operator>
    <operator activated="true" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate" width="90" x="514" y="34">
    <list key="aggregation_attributes">
    <parameter key="Supply" value="sum"/>
    </list>
    </operator>
    <connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
    <connect from_op="Read Excel (2)" from_port="output" to_op="Process Documents from Data (2)" to_port="example set"/>
    <connect from_op="Process Documents from Data (2)" from_port="example set" to_port="result 3"/>
    <connect from_op="Process Documents from Data (2)" from_port="word list" to_op="Process Documents from Data" to_port="word list"/>
    <connect from_op="Process Documents from Data" from_port="example set" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Process Documents from Data" from_port="word list" to_port="result 2"/>
    <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/>
    <portSpacing port="sink_result 3" spacing="0"/>
    <portSpacing port="sink_result 4" spacing="0"/>
    </process>
    </operator>
    </process>
    You can use the Extract Macro operator to  define the keyword (in order to avoid setting this keyword in the parameters of  the Aggregate operator.
    Did these processes answer to your need ?
    If not can you precise what you want to perform ?
    Regards,
    Lionel
    Hi again @asn4293,
    How said in my previous post, I added the Extract Macro operator to define automatically the keyword in the Aggregate operator.
    Here the new release :
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    </list>
    </list>
    </operator>
    </list>
    </list>
    </operator>
    <operator activated="true" class="extract_macro" compatibility="8.1.003" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="187">
    <parameter key="macro" value="keyWord"/>
    <parameter key="macro_type" value="data_value"/>
    <parameter key="attribute_name" value="Matching Text"/>
    <parameter key="example_index" value="1"/>
    <list key="additional_macros"/>
    </operator>
    <operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="313" y="187">
    </process>
    </operator>
    </process>
    </operator>
    <parameter key="%{keyWord}" value="sum"/>
    </list>
    </operator>
    <connect from_op="Read Excel (2)" from_port="output" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Extract Macro" from_port="example set" to_op="Process Documents from Data (2)" to_port="example set"/>
    </process>
    </operator>
    </process>
    I hope it helps,
    Regards,
    Lionel
    OP
    Hi @lionelderkrikor,
    Thank you so very much, sorry for late reply because I was testing it in various aspects and it fitted in all situations.
    I was trying to find the word from the list matching the master data and it works fine with multiple columns and each row is defined as the separate ID which is also working.
    Thank you for help and have a nice day.
    Hello @asn4293,
    "...sorry for late reply...." : I started to worry...:smileyvery-happy:
    You're welcome.
    Have a nice day too.
    Regards,
    Lionel
