So I have to find the number of specific words occurences in the excel file. For example I have ten columns in which it have in each row we have one employee. Each employee profile may contain one word which we want to find with number of occurences.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="187">
<parameter key="excel_file" value="C:\Users\shahida1\Desktop\Sample Testing Text Mining.xlsx"/>
<parameter key="imported_cell_range" value="A1:F36"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="User Sys ID.true.integer.id"/>
<parameter key="1" value="Employee Id.true.integer.attribute"/>
<parameter key="2" value="Last name.true.polynominal.attribute"/>
<parameter key="3" value="First name.true.polynominal.attribute"/>
<parameter key="4" value="Business Unit.true.polynominal.attribute"/>
<parameter key="5" value="Functional Area.true.polynominal.attribute"/>
</list>
<operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="246" y="187">
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights"/>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="447" y="187">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="238"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="313" y="238"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="112" y="442">
<parameter key="sheet_number" value="2"/>
<parameter key="imported_cell_range" value="A1:A2"/>
</list>
<parameter key="0" value="Matching Text.true.polynominal.attribute"/>
</list>
<operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="442">
<parameter key="attribute" value="Matching Text"/>
<operator activated="true" class="operator_toolbox:filter_tokens_using_exampleset" compatibility="1.0.000" expanded="true" height="82" name="Filter Tokens Using ExampleSet" width="90" x="581" y="340"/>
<connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Filter Tokens Using ExampleSet" to_port="example set"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Tokens Using ExampleSet" to_port="document"/>
<connect from_op="Filter Tokens Using ExampleSet" from_port="document" to_port="result 1"/>
</process>
</process>
This is the file which I am working on.
https://drive.google.com/open?id=1PT38TyBmoIHDfIVCAk7Je3l3AXRP-4Gi
