reading Facebook open graph into database
Hi
I am wantingto read Facebook opengraph information into a clients DB. I have formatted the input into Facebook and I am processing the recursive requests. The problem I am having is that I am just not able to get the JSON into a format that I can read into the DB. Multple splits and transposes later and I am still no where. Is there an easier way to read this format of code in:
"posts":{
"data":[
"comments":{
"data":[
"created_time":"2018-04-19T06:09:10+0000",
"from":{
"name":"User 1",
"id":"12345"
"message":"Thank you",
"id":"12345_12345"
"created_time":"2018-04-19T06:11:50+0000",
"from":{
"name":"User 2",
"id":"567890"
"message":"for your help",
"id":"12345_567890"
The format it comes from in the open graph means that there can be sub comments of comments which is where I am fowling up as I end up with a matrix instead of a data table.
Hi Robin,
I am also facing some troubles with the Facebook operators. Can you post a sample process? I've been able to get some data using the Python SDK, but I would like to use RapidMiner instead.
Going back to your post, maybe you could try generating an attribute "parent comment id", leaving it blank for an initial comment. Note that you will be losing some information, because the subcomment will no longer be chained (maybe they can be sorted by time).
Looking forward to seeing a process!
so yes @robin I too am having trouble with your JSON array. Something weird about its formatting.
FYI the "JSON to Data" operator in the Text Processing extension really likes everything to be in {} rather than []. A simple "Replace Tokens" operator is usually my fix for this.
Scott
Scott
@robin I'm getting a malformed JSON file, what kind of error are you getting?
