🎉Community Raffle - Win $25
Join and Win
reading Facebook open graph into database
User: "robin"
New Altair Community Member
Updated by Jocelyn
Hi
I am wantingto read Facebook opengraph information into a clients DB. I have formatted the input into Facebook and I am processing the recursive requests. The problem I am having is that I am just not able to get the JSON into a format that I can read into the DB. Multple splits and transposes later and I am still no where. Is there an easier way to read this format of code in:
   "posts":{
      "data":[
            "comments":{
               "data":[
                     "created_time":"2018-04-19T06:09:10+0000",
                     "from":{
                        "name":"User 1",
                        "id":"12345"
                     "message":"Thank you",
                     "id":"12345_12345"
                     "created_time":"2018-04-19T06:11:50+0000",
                     "from":{
                        "name":"User 2",
                        "id":"567890"
                     "message":"for your help",
                     "id":"12345_567890"
The format it comes from in the open graph means that there can be sub comments of comments which is where I am fowling up as I end up with a matrix instead of a data table.
1 - 2 of 21
    User: "Thomas_Ott"
    Accepted Answer
    @SGolbert and @robin one other possibility is that FB is changing their API's because of this whole Cambridge Analytica business.
    User: "sgenzer"
    Accepted Answer
    so yes @robin I too am having trouble with your JSON array. Something weird about its formatting.
    FYI the "JSON to Data" operator in the Text Processing extension really likes everything to be in {} rather than []. A simple "Replace Tokens" operator is usually my fix for this.
    Scott
