1 - 6 of
61
Are you able to successfully install other extensions?
Also, remember that the Weka extension isn't just one operator called "Weka" but rather it is a set of modeling extensions using algorithms from the open-source Weka project. If you look in your extensions folder in your operator list, it actually looks like this:
hello @putrilestarig - please send me your rapidminer-studio.log file (in your .RapidMiner folder) via private message and I will take a look.
Scott
Hi,
Step 1: Try Restarting the Application, if this does not work try step 2
Step 2: Switch off the Anti Virus on your computer and Try reinstalling the extension again.
Make sure you have the updated JAVA Version.
