🎉Community Raffle - Win $25
Join and Win
"How to use Open WordNet Dictionary operator"
User: "luc_bartkowski"
New Altair Community Member
Updated by Jocelyn
I'm doing Text Analytics.
I'm living in The Nederlands so my primairy language is Dutch.
I want to optimize my process by using the "Stem WordNet" operator.
I found an Open Dutch WordNet implementation at https://github.com/cltl/OpenDutchWordnet
It's stated that this project is based on Wordnet standards. It includes a lot of .sh scripts en .py Python programs.
I can't find/select a "directory" in this project that the RapidMiner "Open WordNet Dictionary" operator would accept.
I compared the content of the GitHub folder with http://wordnetcode.princeton.edu/3.0/. I don't see an equivalent directory/file structure.
The documentation states: "The original WordNet 3.0 synset with offset 06722453 now contains Dutch synonyms."
I don't want to spend much time to learn about Wordnet, its architecture and related shell/Python software development.
I do want to spend as much time as possible learning RapidMiner using the right operators.
Question: How do I integrate this OpenDutchWordnet GitHub project and/or "The original WordNet 3.0 synset with offset 06722453" using the "Open WordNet Dictionary" and "Stem WordNet" operators? Which URL should I download to store a local directory that "Open Wordnet Dictionary" would be able to use?
1 - 5 of 51
    User: "Thomas_Ott"
    The way I installed the English version of Wordnet is download the entire thing and put it into a directory I named 'dictionary.' Then I used the Open Wordnet Dictionary operator and selected the 'dictionary' folder in the directory parameter.
    However, I fear this might not work in your case because the Github repo you reference is mainly a python implementation. This would require you to probably use an Execute Python operator to wrap it all together inside your Process Documents from Data/Documents operator.
    User: "ahootanha"
    Hi I did all the steps but
    Not running Please help me ...
    My input is an Excel file
    User: "YYH"
    Altair Employee
    Hi @ahootanha,
    It can be downloaded from Princeton University website (unzip the downloaded WordNet-3.0.tar.gz twice) https://wordnet.princeton.edu/download/current-version
    After unzip you should configure "open wordnet dictionary" directory to a local folder like this
    \\path_to_wordNet-3.0\dict
    HTH,
    YY
    User: "ahootanha"
    Hello
    I did
    But again the same error was received ...
    help me
    User: "ahootanha"
    Hello please someone help me I really do not know why it's not running. Does anyone have a Twitter run example?
