Altair RISE
Nominate Yourself Now!
Problem with batch meshing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am a new user of batchmesh with hypermesh..
I tried to batch automatically a geometry and export the mesh by using the code I found in command.tcl.
It works perfectly with the command window in Hypermesh.
I tried to mesh it with this windows command in a .bat :
'C:/Program Files/Altair/2017/hw/bin/win64/hw.exe' -b -clientconfig hwfepre.dat -uAnsys -tcl myscript.tcl
And I get this error message :
Command line Tcl script read failed.
0
    while executing
'*dictionaryload sensors 1 'C:/Program Files/Altair/2017/templates/feoutput/ansys/ansys.tpl' 'SOLID186''
    (file 'myscript.tcl' line 35)
    invoked from within
'source 'myscript.tcl''
Thanks a lot for your help!
Here below myscript.tcl
*geomimport 'auto_detect' 'C:/folder/bride.iges' 'CleanupTol=-0.01' 'DoNotMergeEdges=off' 'ImportBlanked=off' 'ScaleFactor=1.0'
*end_batch_import
*createnode 0 0 0 0 0 0
*createnode 0 0 100 0 0 0
*surfaceconefull 1 2 52 52 1 100
*createmark solids 1 1
*createmark surfaces 2 17
*trim_solids_by_surfaces 1 2 1
*createmark solids 1 1 2
*solidmap_solids_begin 1 829568 2
  *createmark lines 1 72
  *solidmap_solids_set_elemsize 1 0.785228065
  *createmark lines 1 75
  *solidmap_solids_set_elemsize 1 1.1
  *createmark lines 1 56
  *solidmap_solids_set_elemsize 1 1.5
  *createmark lines 1 46 55 57 64 67 71 90 94 95
  *solidmap_solids_set_elemsize 1 2.19866837
  *createmark lines 1 81
  *solidmap_solids_set_elemsize 1 2.5
*solidmap_solids_end
*createsensor 'ET_1'
*createmark sensors 1 'ET_1'
*renumber sensors 1 1 1 0 0
*attributeupdateint sensors 1 141 8 0 0 186
*createmark materials 1
*clearmark materials 1
*collectorcreate materials 'MAT1' '' 9
*createmark materials 1 'MAT1'
*renumber materials 1 1 1 0 0
*attributeupdateentity components 2 3081 8 2 0 sensors 1
*elementtype 210 7
*elementtype 213 7
*elementtype 215 7
*elementtype 220 7
*createmark elements 2 240-2629 2851-5723
*elementsettypes 2
*createmark components 1 'B-REP'
*materialupdate components 1 'MAT1'
*startnotehistorystate {Hide Components 'Points'}
*createmark components 3 'Points'
*createstringarray 2 'elements_on' 'geometry_off'
*hideentitybymark 3 1 2
*endnotehistorystate {Hide Components 'Points'}
*createstringarray 2 'elements_off' 'geometry_on'
*startnotehistorystate {Hide Components 'B-REP'}
*createmark components 3 'B-REP'
*endnotehistorystate {Hide Components 'B-REP'}
*startnotehistorystate {Hide Components 'auto1'}
*createmark components 3 'auto1'
*endnotehistorystate {Hide Components 'auto1'}
*retainmarkselections 0
*createstringarray 2 'HM_MERGELOADS_IN_LOADSTEP ' 'HMCOMMENTS_SKIP'
*feoutputwithdata 'C:/Program Files/Altair/2017/templates/feoutput/ansys/ansys.tpl' 'C:/folder/V1.cdb' 0 0 0 1 2
1 - 1 of 11
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hello @matrou
    In most cases you have to load the template file, instead of select UserProfile if using BatchMode.
    Please try to add the this line for beginning of your script and remove '-uAnsys' argument.
     *templatefileset [file join [hm_info -appinfo ALTAIR_HOME] templates feoutput ansys ansys.tpl];
    Thanks,
    Imoto
