I am a new user of batchmesh with hypermesh..
I tried to batch automatically a geometry and export the mesh by using the code I found in command.tcl.
It works perfectly with the command window in Hypermesh.
I tried to mesh it with this windows command in a .bat :
'C:/Program Files/Altair/2017/hw/bin/win64/hw.exe' -b -clientconfig hwfepre.dat -uAnsys -tcl myscript.tcl
And I get this error message :
Command line Tcl script read failed.
while executing
'*dictionaryload sensors 1 'C:/Program Files/Altair/2017/templates/feoutput/ansys/ansys.tpl' 'SOLID186''
(file 'myscript.tcl' line 35)
invoked from within
'source 'myscript.tcl''
Thanks a lot for your help!
Here below myscript.tcl
*geomimport 'auto_detect' 'C:/folder/bride.iges' 'CleanupTol=-0.01' 'DoNotMergeEdges=off' 'ImportBlanked=off' 'ScaleFactor=1.0'
*end_batch_import
*createnode 0 0 0 0 0 0
*createnode 0 0 100 0 0 0
*surfaceconefull 1 2 52 52 1 100
*createmark solids 1 1
*createmark surfaces 2 17
*trim_solids_by_surfaces 1 2 1
*createmark solids 1 1 2
*solidmap_solids_begin 1 829568 2
*createmark lines 1 72
*solidmap_solids_set_elemsize 1 0.785228065
*createmark lines 1 75
*solidmap_solids_set_elemsize 1 1.1
*createmark lines 1 56
*solidmap_solids_set_elemsize 1 1.5
*createmark lines 1 46 55 57 64 67 71 90 94 95
*solidmap_solids_set_elemsize 1 2.19866837
*createmark lines 1 81
*solidmap_solids_set_elemsize 1 2.5
*solidmap_solids_end
*createsensor 'ET_1'
*createmark sensors 1 'ET_1'
*renumber sensors 1 1 1 0 0
*attributeupdateint sensors 1 141 8 0 0 186
*createmark materials 1
*clearmark materials 1
*collectorcreate materials 'MAT1' '' 9
*createmark materials 1 'MAT1'
*renumber materials 1 1 1 0 0
*attributeupdateentity components 2 3081 8 2 0 sensors 1
*elementtype 210 7
*elementtype 213 7
*elementtype 215 7
*elementtype 220 7
*createmark elements 2 240-2629 2851-5723
*elementsettypes 2
*createmark components 1 'B-REP'
*materialupdate components 1 'MAT1'
*startnotehistorystate {Hide Components 'Points'}
*createmark components 3 'Points'
*createstringarray 2 'elements_on' 'geometry_off'
*hideentitybymark 3 1 2
*endnotehistorystate {Hide Components 'Points'}
*createstringarray 2 'elements_off' 'geometry_on'
*startnotehistorystate {Hide Components 'B-REP'}
*createmark components 3 'B-REP'
*endnotehistorystate {Hide Components 'B-REP'}
*startnotehistorystate {Hide Components 'auto1'}
*createmark components 3 'auto1'
*endnotehistorystate {Hide Components 'auto1'}
*retainmarkselections 0
*createstringarray 2 'HM_MERGELOADS_IN_LOADSTEP ' 'HMCOMMENTS_SKIP'
*feoutputwithdata 'C:/Program Files/Altair/2017/templates/feoutput/ansys/ansys.tpl' 'C:/folder/V1.cdb' 0 0 0 1 2
