🎉Community Raffle - Win $25
Join and Win
Process Documents from Files: Include all subdirectories
User: "roger_rutishaus"
New Altair Community Member
Updated by Jocelyn
Hi all,
In the parameters box of "Process Documents from Files" I can set the "text directories".
I have a lot of html files on local hard drive, in a folder called "webpage", with many subfolders (~100). Too many subfolders to add them all separately. I am missing a checkbox that enables to include all the subfolders. Is there a way I can achieve this? I have created a CSV file with columns "class name" and "directory". Would be great if i could import this.
Cheers, Roger
1 - 5 of 51
    User: "Telcontar120"
    Accepted Answer
    If you don't want to enter the directories manually in that operator (which you can do, it sounds like you understand that), then another option would be to use "Loop Files" which does have a "recursive directory" parameter option and do your document processing inside the loop.
    OP
    Thank you Brian. Yes, I know I can enter them manually, but I have like 100 subfolders and it would take me too long.
    I'll give the "Loop Files" a try!
    User: "JEdward"
    Here is a hastily cobbled together example showing how you might use loop files with your CSV of directories & class labels.
    This might be useful if for some reason your directories might be in different locations rather than all nested nicely.
    It uses macros to populate the parameters wanted.
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_csv" compatibility="8.1.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="85">
    <list key="annotations"/>
    <list key="data_set_meta_data_information"/>
    </operator>
    <operator activated="true" class="loop_examples" compatibility="8.1.001" expanded="true" height="103" name="Loop Examples" width="90" x="179" y="85">
    <operator activated="true" class="extract_macro" compatibility="8.1.001" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="85">
    <parameter key="macro" value="myClass"/>
    <parameter key="macro_type" value="data_value"/>
    <parameter key="attribute_name" value="Class"/>
    <parameter key="example_index" value="%{example}"/>
    <list key="additional_macros">
    <parameter key="myDirectory" value="Directory"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">Extract the directory and class label values as macros</description>
    </operator>
    <operator activated="true" class="concurrency:loop_files" compatibility="8.1.001" expanded="true" height="82" name="Loop Files" width="90" x="246" y="85">
    <parameter key="directory" value="%{myDirectory}"/>
    <operator activated="true" class="text:documents_to_data" compatibility="8.1.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="34">
    <parameter key="text_attribute" value="text"/>
    <description align="center" color="transparent" colored="false" width="126">Read the text</description>
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.1.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34">
    <list key="function_descriptions">
    <parameter key="Label" value="%{myClass}"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">Add the class macro as the label attribute.</description>
    </operator>
    <operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role" width="90" x="514" y="34">
    <parameter key="attribute_name" value="Label"/>
    <parameter key="target_role" value="label"/>
    <list key="set_additional_roles"/>
    </operator>
    <connect from_port="file object" to_op="Documents to Data" to_port="documents 1"/>
    <connect from_op="Documents to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_port="output 1"/>
    <portSpacing port="source_file object" spacing="0"/>
    <portSpacing port="source_input 2" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">Use the directory macro as a parameter in Loop Files</description>
    </operator>
    <connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Extract Macro" from_port="example set" to_op="Loop Files" to_port="input 1"/>
    <connect from_op="Loop Files" from_port="output 1" to_port="output 1"/>
    <portSpacing port="source_example set" spacing="0"/>
    <portSpacing port="sink_example set" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">Loop the CSV</description>
    </operator>
    <operator activated="true" class="append" compatibility="8.1.001" expanded="true" height="82" name="Append" width="90" x="313" y="85"/>
    <operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="447" y="34">
    <list key="specify_weights"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
    <connect from_port="document" to_op="Tokenize" to_port="document"/>
    <connect from_op="Tokenize" from_port="document" to_port="document 1"/>
    <portSpacing port="source_document" spacing="0"/>
    <portSpacing port="sink_document 1" spacing="0"/>
    <portSpacing port="sink_document 2" spacing="0"/>
    <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="80" y="124">Some Preprocessing here</description>
    </process>
    </operator>
    <connect from_op="Read CSV" from_port="output" to_op="Loop Examples" to_port="example set"/>
    <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/>
    <connect from_op="Append" from_port="merged set" to_op="Process Documents from Data" to_port="example set"/>
    <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
    </process>
    </operator>
    </process>
    OP
    Thank you JEdward! Will give it a try
    OP
    Brian, it worked nicely. great!
    here's my solution (text and terms):
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <operator activated="true" class="concurrency:loop_files" compatibility="8.1.001" expanded="true" height="82" name="Loop Files (2)" width="90" x="45" y="34">
    <parameter key="directory" value="D:\_BT\Textanalyse\www.htwchur.ch\digital-science\forschung-und-dienstleistung"/>
    <parameter key="filter_type" value="glob"/>
    <parameter key="recursive" value="true"/>
    <parameter key="enable_macros" value="false"/>
    <parameter key="macro_for_file_name" value="file_name"/>
    <parameter key="macro_for_file_type" value="file_type"/>
    <parameter key="macro_for_folder_name" value="folder_name"/>
    <parameter key="reuse_results" value="false"/>
    <parameter key="enable_parallel_execution" value="true"/>
    <operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="112" y="34">
    <parameter key="extract_text_only" value="true"/>
    <parameter key="use_file_extension_as_type" value="true"/>
    <parameter key="content_type" value="txt"/>
    <parameter key="encoding" value="UTF-8"/>
    </operator>
    <connect from_port="file object" to_op="Read Document" to_port="file"/>
    <connect from_op="Read Document" from_port="output" to_port="output 1"/>
    </process>
    </operator>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents (2)" width="90" x="45" y="238">
    <parameter key="create_word_vector" value="true"/>
    <parameter key="vector_creation" value="TF-IDF"/>
    <parameter key="add_meta_information" value="true"/>
    <parameter key="keep_text" value="true"/>
    <parameter key="prune_method" value="none"/>
    <parameter key="prune_below_percent" value="3.0"/>
    <parameter key="prune_above_percent" value="30.0"/>
    <parameter key="prune_below_rank" value="0.05"/>
    <parameter key="prune_above_rank" value="0.95"/>
    <parameter key="datamanagement" value="double_sparse_array"/>
    <parameter key="data_management" value="auto"/>
    <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="246" y="34">
    <parameter key="query_type" value="XPath"/>
    <list key="string_machting_queries"/>
    <parameter key="attribute_type" value="Nominal"/>
    <list key="regular_expression_queries"/>
    <list key="regular_region_queries"/>
    <list key="xpath_queries">
    <parameter key="p-class-bodytext" value="//h:p[@class=&amp;quot;bodytext&quot;]//h:p[text()]"/>
    <parameter key="p-class-bodytext-li" value="//h:div[@class=&amp;quot;conttext&quot;]//h:p[text()]"/>
    </list>
    <list key="namespaces"/>
    <parameter key="ignore_CDATA" value="true"/>
    <parameter key="assume_html" value="true"/>
    <list key="index_queries"/>
    <list key="jsonpath_queries"/>
    <operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content (2)" width="90" x="112" y="34">
    <parameter key="extract_content" value="true"/>
    <parameter key="minimum_text_block_length" value="6"/>
    <parameter key="override_content_type_information" value="true"/>
    <parameter key="neglegt_span_tags" value="true"/>
    <parameter key="neglect_p_tags" value="true"/>
    <parameter key="neglect_b_tags" value="true"/>
    <parameter key="neglect_i_tags" value="true"/>
    <parameter key="neglect_br_tags" value="true"/>
    <parameter key="ignore_non_html_tags" value="true"/>
    </operator>
    <connect from_port="segment" to_op="Extract Content (2)" to_port="document"/>
    <connect from_op="Extract Content (2)" from_port="document" to_port="document 1"/>
    <portSpacing port="source_segment" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="text:filter_documents_by_content" compatibility="8.1.000" expanded="true" height="82" name="Filter Documents (by Content)" width="90" x="447" y="34">
    <parameter key="condition" value="contains match"/>
    <parameter key="regular_expression" value="."/>
    <parameter key="case_sensitive" value="false"/>
    <parameter key="invert condition" value="false"/>
    </operator>
    <connect from_port="document" to_op="Cut Document" to_port="document"/>
    <connect from_op="Cut Document" from_port="documents" to_op="Filter Documents (by Content)" to_port="documents 1"/>
    <connect from_op="Filter Documents (by Content)" from_port="documents" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="multiply" compatibility="8.1.001" expanded="true" height="103" name="Multiply (2)" width="90" x="179" y="238"/>
    <operator activated="true" class="remove_duplicates" compatibility="8.1.001" expanded="true" height="103" name="Remove Duplicates" width="90" x="380" y="340">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="text"/>
    <parameter key="attributes" value=""/>
    <parameter key="use_except_expression" value="false"/>
    <parameter key="value_type" value="attribute_value"/>
    <parameter key="use_value_type_exception" value="false"/>
    <parameter key="except_value_type" value="time"/>
    <parameter key="block_type" value="attribute_block"/>
    <parameter key="use_block_type_exception" value="false"/>
    <parameter key="except_block_type" value="value_matrix_row_start"/>
    <parameter key="invert_selection" value="false"/>
    <parameter key="include_special_attributes" value="true"/>
    <parameter key="treat_missing_values_as_duplicates" value="true"/>
    </operator>
    <operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="514" y="340">
    <parameter key="select_attributes_and_weights" value="true"/>
    <list key="specify_weights">
    <parameter key="text" value="1.0"/>
    </list>
    </operator>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="648" y="340">
    <parameter key="keep_text" value="false"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="34">
    <parameter key="mode" value="non letters"/>
    <parameter key="characters" value=".:"/>
    <parameter key="language" value="English"/>
    <parameter key="max_token_length" value="3"/>
    </operator>
    <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="179" y="34"/>
    <operator activated="true" class="text:filter_stopwords_french" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (3)" width="90" x="313" y="34"/>
    <operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="447" y="34">
    <parameter key="min_chars" value="4"/>
    <parameter key="max_chars" value="200"/>
    </operator>
    <operator activated="true" class="text:filter_tokens_by_pos" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by POS Tags)" width="90" x="581" y="34">
    <parameter key="language" value="German"/>
    <parameter key="expression" value="NN"/>
    <parameter key="invert_filter" value="false"/>
    </operator>
    <connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
    <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
    <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
    <connect from_op="Filter Stopwords (3)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
    <connect from_op="Filter Tokens (2)" from_port="document" to_op="Filter Tokens (by POS Tags)" to_port="document"/>
    <connect from_op="Filter Tokens (by POS Tags)" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="782" y="391"/>
    <operator activated="true" class="remove_duplicates" compatibility="8.1.001" expanded="true" height="103" name="Remove Duplicates (2)" width="90" x="380" y="34">
    </operator>
    <connect from_port="input 1" to_op="Loop Files (2)" to_port="input 1"/>
    <connect from_op="Loop Files (2)" from_port="output 1" to_op="Process Documents (2)" to_port="documents 1"/>
    <connect from_op="Process Documents (2)" from_port="example set" to_op="Multiply (2)" to_port="input"/>
    <connect from_op="Multiply (2)" from_port="output 1" to_op="Remove Duplicates (2)" to_port="example set input"/>
    <connect from_op="Multiply (2)" from_port="output 2" to_op="Remove Duplicates" to_port="example set input"/>
    <connect from_op="Remove Duplicates" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
    <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
    <connect from_op="Process Documents" from_port="example set" to_port="result 2"/>
    <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
    <connect from_op="WordList to Data" from_port="example set" to_port="result 3"/>
    <connect from_op="Remove Duplicates (2)" from_port="example set output" to_port="result 1"/>
    <portSpacing port="sink_result 3" spacing="0"/>
    <portSpacing port="sink_result 4" spacing="0"/>
    </process>
    </operator>
    </process>
    only terms:
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="concurrency:loop_files" compatibility="8.1.001" expanded="true" height="82" name="Loop Files (2)" width="90" x="112" y="34">
    <parameter key="directory" value="D:\_BT\Textanalyse\www.htwchur.ch\digital-science\forschung-und-dienstleistung\institut-sii\forschungsfelder"/>
    </operator>
    </process>
    </operator>
    <operator activated="true" class="loop_collection" compatibility="8.1.001" expanded="true" height="82" name="Loop Collection" width="90" x="246" y="34">
    <parameter key="set_iteration_macro" value="false"/>
    <parameter key="macro_name" value="iteration"/>
    <parameter key="macro_start_value" value="1"/>
    <parameter key="unfold" value="true"/>
    <operator activated="true" class="text:cut_document" compatibility="8.1.000" expanded="true" height="68" name="Cut Document" width="90" x="112" y="34">
    <parameter key="div-class-conttext" value="//h:div[@class=&amp;quot;conttext&quot;]//h:p[text()]"/>
    </list>
    <operator activated="false" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="112" y="544">
    <parameter key="transform_to" value="lower case"/>
    </operator>
    <operator activated="false" class="text:filter_tokens_by_pos" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by POS Tags)" width="90" x="179" y="238">
    </operator>
    <operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content" width="90" x="45" y="34">
    <parameter key="minimum_text_block_length" value="4"/>
    </operator>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="179" y="34">
    </operator>
    <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="45" y="136"/>
    <operator activated="true" class="text:filter_stopwords_french" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (3)" width="90" x="179" y="136"/>
    <operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="45" y="238">
    </operator>
    <operator activated="true" class="text:extract_token_number" compatibility="8.1.000" expanded="true" height="68" name="Extract Token Number" width="90" x="313" y="238">
    <parameter key="metadata_key" value="token_number"/>
    <parameter key="condition" value="all"/>
    <parameter key="invert_condition" value="false"/>
    </operator>
    <connect from_port="segment" to_op="Extract Content" to_port="document"/>
    <connect from_op="Extract Content" from_port="document" to_op="Tokenize (2)" to_port="document"/>
    <connect from_op="Filter Tokens (2)" from_port="document" to_op="Extract Token Number" to_port="document"/>
    <connect from_op="Extract Token Number" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="text:filter_documents_by_content" compatibility="8.1.000" expanded="true" height="82" name="Filter Documents (by Content)" width="90" x="380" y="34">
    </operator>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="581" y="34">
    <connect from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="write_excel" compatibility="8.1.001" expanded="true" height="82" name="Write Excel" width="90" x="715" y="34">
    <parameter key="excel_file" value="D:\_BT\Textanalyse\saveTextInTable3.xlsx"/>
    <parameter key="file_format" value="xlsx"/>
    <parameter key="sheet_name" value="RapidMiner Data"/>
    <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
    <parameter key="number_format" value="#.0"/>
    </operator>
    <connect from_port="single" to_op="Cut Document" to_port="document"/>
    <connect from_op="Filter Documents (by Content)" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
    <connect from_op="Process Documents" from_port="example set" to_op="Write Excel" to_port="input"/>
    <connect from_op="Write Excel" from_port="through" to_port="output 1"/>
    <portSpacing port="source_single" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Loop Files (2)" from_port="output 1" to_op="Loop Collection" to_port="collection"/>
    <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
