Process Documents from Files: Include all subdirectories
User: "roger_rutishaus"
New Altair Community Member
Updated by Jocelyn
Hi all,
In the parameters box of "Process Documents from Files" I can set the "text directories".
I have a lot of html files on local hard drive, in a folder called "webpage", with many subfolders (~100). Too many subfolders to add them all separately. I am missing a checkbox that enables to include all the subfolders. Is there a way I can achieve this? I have created a CSV file with columns "class name" and "directory". Would be great if i could import this.
Cheers, Roger
1 - 1 of 11
    User: "Telcontar120"
    Accepted Answer
    If you don't want to enter the directories manually in that operator (which you can do, it sounds like you understand that), then another option would be to use "Loop Files" which does have a "recursive directory" parameter option and do your document processing inside the loop.
