🎉Community Raffle - Win $25
Join and Win
"How to work and use word2vec"
User: "khazan"
Banned
Updated by Jocelyn
Hello
I want to use Word2vec to convert sentences to a vector
But I do not know how to do it? My data is Twitter.
Please help me by sending the operator image
Thanks
1 - 24 of 241
    User: "David_A"
    New Altair Community Member
    Hi and welcome to the community.
    What you need is first install the Word2Vec extension from the RapidMiner marketplace.
    Once done you'll find the Word2Vec Operator in the Operators search bar (or use the global search).
    You can check this excellent post by Martin on how to apply the extension:
    https://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Synonym-Detection-with-Word2Vec/ta-p/43860
    Best,
    David
    Hello
    Thank
    I saw the link
    Unfortunately, the pictures are not clear.
    You may want to send an image of the use of this operator to analyze emotions
    Many thanks
    Best,
    David
    Dear @khazan,
    the mentioned post has an attached .zip. It contains the full analysis so you can load it into your RM and use it yourself.
    Best,
    Martin
    Hello
    Thank you for your attention
    I downloaded the sample file to use Word2vec And I entered the RapidMiner.
    But there is an error.
    And I do not know what the process of using this operator is.
    Please give me guidance.
    thank you again
    Hi,
    this operator expects a collection of tokenized documents as an input. Not an Example Set.
    ~Martin
    User: "thomas_wiedmann"
    I also try this nice example and get this error
    My input data
    My data looks like this
    Any hint...?
    EDIT - Add RM Logfile
    Thanks!
    Thomas
    Hi,
    how many docs do you feed in? More than number of negative samples? Can you please try more?
    Best,
    Martin
    Only this one example from the web page of point 1
    The data is provided in one flat file for each hotel with the following structure:
    <Overall Rating>4
    <Avg. Price>$302
    <URL>http://www.tripadvisor.com/ShowUserReviews-g60878-d100504-r22932337-Hotel_Monaco_Seattle_a_Kimpton_Hotel-Seattle_Washington.html
    <Author>selizabethm
    <Content>Wonderful time- even with the snow! What a great experience! From the goldfish in the room (which my daughter loved) to the fact that the valet parking staff who put on my chains on for me it was fabulous. The staff was attentive and went above and beyond to make our stay enjoyable. Oh, and about the parking: the charge is about what you would pay at any garage or lot- and I bet they wouldn't help you out in the snow!
    <Date>Dec 23, 2008
    <No. Reader>-1
    <No. Helpful>-1
    <Overall>5
    <Value>4
    <Rooms>5
    <Location>5
    <Cleanliness>5
    <Check in / front desk>5
    <Service>5
    <Business service>-1
    Hi,
    you need to provide more data to be able to run word2vec. A single example won't work to train the model. I've tested it and it starts to work with 5 examples.
    Best,
    Martin
    I copied the original record and changed something. Now the database is two *.dat files.
    After this, I get the same error...
    EDIT
    Ok, I build 5 data files and try again...
    Regards,
    Thomas
    Right, with five files, the process works. I continue testing now...
    Thanks!
    Thomas
    @mschmitz
    You wrote: "how many docs do you feed in? More than number of negative samples? Can you please try more?"
    Now I try with five small (german) Textsample and the process failed like before. Is there any lower boundary or param?
    Please explain..
    Regards
    Thomas
    Hi,
    well the algorithm itself makes only sense if you have a lot of data. Honestly it would make some sense if i add an error for less than a thousand examples. Less is usally not yielding good results.
    I am not sure where the exact bounday of 5 comes from though.
    Best,
    Martin
    Hello
    I've preprocessed and tokenize the data, but it has an error.
    look?
    Please please
    Thankful
    Hi,
    Process Documents converts this into a bag of words. Please have a look on the example processes. It shows you how to do this with loop collection.
    Best,
    Martin
    I want to use word2vec to analyze emotions
    I downloaded the tutorial from the site
    Instead of entering my text file, I have a csv file and xlsx file
    As transmitted by my loop operator, I read the excel operator, but it has an error in the output
    Please provide guidance on how to use this sample for my csv file
    And that
    These addresses
    C: \ Users \ Martin \ Arbeit \ Tripadvisor
    ../results/Replacement Dictionary
    What is the sample on the site?
    Should I have a dictionary? How? From where?
    Thankful
    hi
    please please helppp me...
    I really need help
    please help me
    Hi,
    please try Read Exel, Nominal to Text and Data to Documents. That should create a collection which can be handled by Loop Collection.
    Best,
    Martin
    I used this way, it has an error
    help
    User: "Thomas_Ott"
    @khazan that error means no data is being passed out of the Loop Collection. I would put a breakpoint in on the Loop Files operator and see if data is reaching the Loop Collection.
    I used but did not have any results
    Please, if there is an alternate operator for loop file, guide me.
    Please tell me how to use word2vec for twitter data? Thanks
    I beg you to help me
    I need a lot to help with this.
    User: "sgenzer"
    Altair Employee
    hello @khazan Some quick recommendations for you:
    • Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)
    • Attach your dataset if possible (use a fictionalized version if there are privacy concerns)
    • Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)
    Scott
