Beam section metadata not present
Toby Wright
Toby Wright Altair Community Member
edited November 2022 in Community Q&A
When trying to create a beam section using the standard section button a beam section is created but I am not able to see/edit any of the entities other than Name and ID. How would I be able to enable these options?
Welcome!
Best Answer
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    edited November 2022 Answer ✓
    We are all using 2021.2 with the same license. Other than that I'm not sure what you mean sorry
    I guess it is called "solver interface" now but are you using the OptiStruct profile or Radioss or some other profile?
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
    I'm not sure exactly which interface you are using from your screenshot?
    How did you get there?
    Opening from model browser I have this: but it doesn't look like the same browser you are in?
  • Toby Wright
    I get the same options when I open from the model browser as I do in the pop up after clicking the standard section button (from the beam sections button in the Mesh ribbon). My colleagues have all of the options that you have when opening so I'm not sure why I don't.
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    Are you using the same profile as your colleagues?  Same model?
  • Toby Wright
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
  • Toby Wright
    I just swapped off OptiStruct and back on and the problem seems to be solved now thank you
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    Great.  Otherwise I was out of ideas Beaming face with smiling eyes
Welcome!
Welcome!
