🎉Community Raffle - Win $25
Join and Win
Beam section metadata not present
Toby WrightUser: "Toby Wright"
Altair Community Member
Updated by Toby Wright
When trying to create a beam section using the standard section button a beam section is created but I am not able to see/edit any of the entities other than Name and ID. How would I be able to enable these options?
1 - 7 of 71
    I'm not sure exactly which interface you are using from your screenshot?
    How did you get there?
    Opening from model browser I have this: but it doesn't look like the same browser you are in?
    OP
    I get the same options when I open from the model browser as I do in the pop up after clicking the standard section button (from the beam sections button in the Mesh ribbon). My colleagues have all of the options that you have when opening so I'm not sure why I don't.
    Are you using the same profile as your colleagues?  Same model?
    OP
    We are all using 2021.2 with the same license. Other than that I'm not sure what you mean sorry
    Ben BuchananUser: "Ben Buchanan"
    Altair Employee
    Accepted Answer
    Updated by Ben Buchanan
    I guess it is called "solver interface" now but are you using the OptiStruct profile or Radioss or some other profile?
    OP
    I just swapped off OptiStruct and back on and the problem seems to be solved now thank you
    Great.  Otherwise I was out of ideas Beaming face with smiling eyes
