hello @ahootanha Some quick recommendations for you so we can help better: • Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply) • Attach your dataset if possible (use a fictionalized version if there are privacy concerns) • Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)
Scott
