🎉Community Raffle - Win $25
Join and Win
problem with use wordnet operator
User: "ahootanha"
New Altair Community Member
Updated by Jocelyn
Hi, I've got a Twitter data entry
I want to use WordPress
But this error appears
Please guide.
Send me a screenshot of the performance
Thanks
1 - 13 of 131
    User: "Pavithra_Rao"
    Hi @ahootanha
    Could you confirm that you have pointed the right directory containing stem dictionary for "Open WordNet Dictionary"?
    Could you please take a screenshot after clicking on 'MoreInfo'
    Also please share the Studio log file found here:  C:\users\<username>\.RapidMiner\
    This will help us debug the issue easily.
    Thanks,
    User: "ahootanha"
    OP
    Hi, Thanks for your reply
    I've run the program many times. But this error is repeated every time
    Please guide
    Thanks
    Hi @ahootanha
    I have few similar process where I use Open wordnet dictionary.
    As shown in below screenshot I point the directory to the folder where I have dictionary saved in following formats:
    process.pngformat of dictionariesxyz.pngProcess using Open wordnet dictionary
    Not sure what format you have saved your stem dictionary. The error seems to be related to file formats, hence it's not able to parse or read the files.
    Also please share the log files to help debug the issue here.
    It will in your .RapidMiner folder :C:\users\<username>\.Rapidminer \**.log
    Hope this helps.
    Cheers,
    Pavithra
    User: "ahootanha"
    OP
    Hello
    I saw this in the log file
    The dictionary was just like you
    Please guide
    Thanks
    Hi @ahootanha
    Could you please attach the .log file here. The screenshot of the log file doesn't really help.
    Thanks,
    Pavithra
    User: "ahootanha"
    OP
    I posted the file
    Please guide
    Thanks
    User: "ahootanha"
    OP
    Hello
    Can no one help me?
    Very necessary
    Please help me
    User: "sgenzer"
    Altair Employee
    hello @ahootanha please be patient. This is a community forum - people volunteer their time to help users when they can. :)
    [EDIT: I just looked at your PDF. You only posted a fragment of your log file rather than the whole thing but it's pretty clear that the Wordnet dictionary is the problem here:
    SEVERE: Process failed: Error reading F:\WordNet-3.0: Could not open dictionary from directory
    F:\WordNet-3.0
    com.rapidminer.operator.UserError: Error reading F:\WordNet-3.0: Could not open dictionary from
    directory F:\WordNet-3.0
    Scott
    User: "ahootanha"
    OP
    Hello Forgive me Believe me, I'm very caught I thank you and the community What should i do now To overcome the problem Please guide Thanks & Regards
    User: "sgenzer"
    Altair Employee
    hello @ahootanha - so I still think the problem is the dictionary path that you're giving that Wordnet operator. Perhaps you can post your XML and your dataset so we can see what you're doing?
    Scott
    User: "Thomas_Ott"
    @ahootanha did you try switching the parameter from 'directory' to 'resource?' I seem to remember that at times it causes a conflict that can be resolved by toggling one or the other.
    User: "ahootanha"
    OP
    Hello
    Thank you for your attention
    I used this data for the exam (Posted)
    I changed my data many times, but there is still the same error.
    May I ask you to do it and send your rapidminer file? Along with the wordnet Dictionary?
    I will be grateful.
    Thanks
    User: "ahootanha"
    OP
    Hello
    Honorable professors
    Please send me an example that uses Twitter data.
    Anything I did not run. And I see the same error ...
    Thanks
