How to evaluate clustering
User: "ahootanha"
New Altair Community Member
Updated by Jocelyn
Hello
I want to compare clusters and evaluate which operators should I use?
And
How do I find the optimal parameters for each clustering method?
Thanks
1 - 5 of 51
    User: "David_A"
    Hi,
    finding optimal settings for clustering is indeed a bit tricky.
    But RapidMiner offers performance measures for clustering or segmentation tasks.
    In the Operator list under Validation -> Segmentation you'll find the corresponding Operators.
    If you have a subset of your data, where you exactly know into which cluster each example belongs, you can also try to set the cluster Attribute as a prediction and optimize the classification performance instead.cluster_performance.png
    Best,
    David
    User: "ahootanha"
    OP
    Hello
    Concept of
    avg within centroid distance -1.0876
    davies bouldin -5.675
    What is?
    User: "ahootanha"
    OP
    I used Silhouette
    What do these results show?
    Please guide
    Thanks
    User: "David_A"
    Hi again,
    I guess the Silhoutte performance comes from a 3rd party extension, so I can't say much about it. But wikipedia has an entry about it:
    https://en.wikipedia.org/wiki/Silhouette_(clustering)
    In short it messaures how similar an Example is to the rest of the cluster. The value is normed between -1 and +1 and a high value indicates a higher similarity.
    The Davies–Bouldin criterion is also quite good explained in wikipedia:
    https://en.wikipedia.org/wiki/Davies%E2%80%93Bouldin_index
    The idea is to maximise the inter-cluster distance (the different between the different clusters) and minimize inter-cluster distances (the points within each cluster should be close together).  Here a lower index is better.
    Best,
    David
    User: "ahootanha"
    OP
    Hello
    Many thanks
    Criterion
    AVG within centroid distance -1.043
    What is?
    What does the Silhouette of each cluster show in the first photo?
