How to Import Data with Date Column YYYY-MM-DD (ISO 8601)
User: "thomas_wiedmann"
New Altair Community Member
Updated by Jocelyn
I try to Import some CSV Data into RapidMiner including some date column. I get ISO 8601 Date format YYYY-MM-DD.
https://en.wikipedia.org/wiki/ISO_8601
Now I will change imported data type from polynominal to date. I just get errors like.
1. Import RAW Data - polynominal
2. Change type to date looks like this "red error monster"
Data
EINGANG
2010-06-07
2011-03-02
2013-03-08
2015-03-02
2017-03-10
2011-01-03
2013-01-02
2015-02-02
2016-12-22
2011-08-09
2013-07-31
2015-07-27
How can I change this ISO_8601 Date standard format to rapidminer date?
Thanks!
Thomas
1 - 4 of 41
    User: "David_A"
    Accepted Answer
    It seems that the import wizard can only handle date that match exactly the predefined formats in the drop-down menu.
    In your case you only habe yyyy-MM-dd and not yyyy-MM-dd HH:mm:ss .
    In this case, just use the Nominal to Date Operator and specify yyyy-MM-dd as date format.
    Best,
    David
    OP
    Ok, but RapidMiner (Nominal to Date Operator) has to transform this column every time I execute the process. It's not the best solution.
    Hope next version will fix that.
    Thanks
    Thomas
    User: "Marco_Boeck"
    Altair Employee
    Accepted Answer
    Hi,
    I cannot reproduce the problem. You can enter "yyyy-MM-dd" in the Date Format field and then it'll work. You need to press "Enter" after changing the date format field or click somewhere outside of the date format textfield for manual changes to take effect, but that's about it.
    Regards,
    Marco
    OP
    Thanks, that's it. I try it several times to change this import format, with no effect. But now it works.
    Thanks, my fault..
    Thomas
