🎉Community Raffle - Win $25
Join and Win
Menu partly in Asian language
User: "Susanna"
New Altair Community Member
Updated by Jocelyn
Dear Rapidminers,
could you please give me a hint how to switch all menu parts into Englisch? Thank you very much in advance.
Best wishes,
Susanna
Rapidminer Menu.pngRapidminer Menu
1 - 8 of 81
    User: "land"
    Hi Susanna,
    looks like Japanese to me. You probably accidently switched the language setting in your RapidMiner installation. Go to the Settings Menu and select Preferences or, if shown in Japanese, the second entry from top.
    Then you should see the preference dialoge like that:
    And then select en instead of ja as shown in my screenshot.
    Good Luck.
    User: "ramanadk"
    I am getting the following language other than the default. How to rectify it
    User: "ramanadk"
    My entire menu is in another language other than English. Please help. The error image is attached
    User: "ramanadk"
    User: "sgenzer"
    Altair Employee
    hi @ramanadk - wow. That's a new one! What's your OS and your language that is installed on your computer?
    Scott
    User: "Marco_Boeck"
    Hi,
    it does look to me like you have some problem with the fonts installed on your computer. It's not a different language, it just looks weird.
    You can change the fonts that are used manually (an option reserved for weird cases like yours). Accessing it is a little bit tricky, but not too much:
    1. Go to the preferences like in your screenshot
    2. Enter "font" into the top-right search field
    3. Change the selected value to "system fonts" (aka the 2nd value in the dropdown list). See attached screenshot.
    4. Restart RapidMiner Studio.
    Regards,
    Marco
    User: "ramanadk"
    Hello
    My OS is Windows 10 and the language installed is English
    thanks
    Dr. S Padma
    User: "sgenzer"
    Altair Employee
    hello Dr. Padma - did you look at the fonts as @Marco_Boeck suggested? That would be my next question as well.
    Scott
