Dear Rapidminers,
could you please give me a hint how to switch all menu parts into Englisch? Thank you very much in advance.
Best wishes,
Susanna
Rapidminer Menu
Hi Susanna,
looks like Japanese to me. You probably accidently switched the language setting in your RapidMiner installation. Go to the Settings Menu and select Preferences or, if shown in Japanese, the second entry from top.
Then you should see the preference dialoge like that:
And then select en instead of ja as shown in my screenshot.
Good Luck.
I am getting the following language other than the default. How to rectify it
hi @ramanadk - wow. That's a new one! What's your OS and your language that is installed on your computer?
Scott
it does look to me like you have some problem with the fonts installed on your computer. It's not a different language, it just looks weird.
You can change the fonts that are used manually (an option reserved for weird cases like yours). Accessing it is a little bit tricky, but not too much:
Marco
Hello
My OS is Windows 10 and the language installed is English
thanks
Dr. S Padma
hello Dr. Padma - did you look at the fonts as @Marco_Boeck suggested? That would be my next question as well.
