Altair RISE
Nominate Yourself Now!
Normalizing cumulative data
User: "kayman"
New Altair Community Member
Updated by Jocelyn
I have a vast amount of sales and repair data for a range of products, and I would like to compare repair vs sales for comparable products. Since the sales ranges can differ a lot (from hundreds to millions) I would first have to scale them all to the same range, and preferably also shift them so the timeframes match. Not all products are sold at the same time, so at a certain moment I need to concert it from a pure calendar / timescale range to something like 'first period of sales, second period and so on ' so I can compare over a 2 year scale.
Hope I make some sense here :-)
I've been playing around already but get stuck in the complexity of it. So what would the best approach to tackle this? Not looking for ready-to-use code nut more of a advice towards common sense steps to take.
1 - 4 of 41
    User: "sgenzer"
    Altair Employee
    hmm that's a good question @kayman. I guess my initial thought would be to use percentages, i.e. "The first 1% of products sold/repairs did this, the next 1% of products sold/repaired did this, etc..."
    Scott
    User: "kayman"
    OP
    Sorry, wasn't very clear about this, bit hard to explain to be honnest
    My data is cummulated, so both my sales and repair data will gradually increase over time, where my sales will be stable at a certain moment (nothing to sell anymore or new product to keep the pockets empty) while my repair might go on a little longer.
    So the scenario is a bit as follows :
    Product A - January - 1000 sales - 0 repair
    Product A - February - 2000 sales (cummulated) - 10 repair (0.5%)
    Product A - March - 3000 sales (cummulated) - 15 repair (cummulated) (0.5%)
    And so on
    Same goes for product B, but sales may start a little later and the quantities are not as high.
    Now, if I keep the quantities as they are the ratio might be the same, but for visual purposes I want to be able to plot my Sales also on the same chart to have a better trent, so for both products the sales need to be scaled to a max of one (or whatever makes sense) so products will low or high sales or both shown with the same altitude.
    The purpose is mainly for visual interpretation, so I can show the trent lines for a given set of products, have the sales (pareto styled) and repair in one chart so outliers or deviations are more visible.
    So the steps I had in mind was first to get my sales and repairs scaled so I don't have to be bothered anymore about the absolute figures, but I'm not sure what works best here. Next would be to window them so the first period of sales gets aligned independent of start time and so on.
    If I only had to be bothered about the actual ratio it would be easier, but I also need the actual sales trend included as repairs will take place longer than sales, so my ratio will naturally increase after end of sales. And the trends should all be equally scaled (the right term escapes me) so they nicely fit on a powerpoint in the end...
    @kayman,
    cumulative data is integrated data. Can't we just differentiate, normalize, integrate again? That would result in a dataset were the maximum delta between to values is 1.
    Best,
    Martin
    User: "sgenzer"
    Altair Employee
    ah I see. Ugh I hate working with cumulative data (or any aggregated data in any form) for this reason and many many others. Sure what @mschmitz says makes sense....
    Scott
