Problem with sentiment analysis
I've got a problem with the Sentiment Analysis by Aylien. I chose the Read Excel Operator and the Analyze Sentiment Operator but it doesn't work. You can see my problem in the screenshot. Maybe anyone already had the same problem and can help me.
Thanks a lot.
Regina
hello @regina_moser welcome to the community! I'd recommend posting your XML process here (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply) and attach your dataset. This way we can replicate what you're doing and help you better.
Scott
Thank you @Thomas_Ott. I added the Operator you recommended to me but now when I run the process it works until the Analyse Sentiment Operator but it doesn't finish. When I end the process I get the message you can see in the Screenshot. Maybe you can help me one more time? ![]()
Thank you in advance.
Hello @sgenzer I followed the tutorial you recommended to me. Here's my XML process.
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<operator activated="true" class="read_excel" compatibility="8.0.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
<parameter key="excel_file" value="/Users/reginamoser/Desktop/jan17-sep17.xls"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1:J8860"/>
<parameter key="encoding" value="SYSTEM"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="German (Austria)"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="RATING_ID.true.integer.attribute"/>
<parameter key="1" value="TITLE.true.polynominal.attribute"/>
<parameter key="2" value="FREE_TEXT.true.polynominal.attribute"/>
<parameter key="3" value="BUSINESS_KEY.true.polynominal.attribute"/>
<parameter key="4" value="VERIFIED.true.integer.attribute"/>
<parameter key="5" value="REASON.true.polynominal.attribute"/>
<parameter key="6" value="BRAND.true.polynominal.attribute"/>
<parameter key="7" value="OVERALL_RATING.true.integer.attribute"/>
<parameter key="8" value="RECOMMEND.true.integer.attribute"/>
<parameter key="9" value="VIN.true.polynominal.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</operator>
</process>
<operator activated="true" class="text:data_to_documents" compatibility="7.5.000" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="34">
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
</operator>
</process>
<operator activated="true" class="com.aylien.textapi.rapidminer:aylien_document_sentiment" compatibility="0.2.000" expanded="true" height="82" name="Analyze Sentiment" width="90" x="447" y="34">
<parameter key="connection" value="Aylien"/>
<parameter key="sentiment_mode" value="document"/>
</operator>
</process>
Maybe you can help me now?
thank you in advance.
Best regards,
Regina
The warning is telling you that the data you are passing from Read Excel operator to the Analyze Sentiment operator is not in document form (i.e. DOC). You will likely need to use a Data to Documents operator betwen the two.
