Regular attributes can't be addressed by an operator after Transposing
The issue is, that after using the "transpose" operator, the operator "select attributes" doesn't confirm the new "attribute".
In the result view it shows me, that there is 1 special attribute (ID) and over 2000 regular attributes. These regular attributes cannot be addressed by an operator. There is only the ID which I can adresse with an operator.
Thank u for ur help
Jonathan
