Hi, I work with an XML-File. I understand that I use the operator Read XML. I don't know how to convert the document without losing the different structure levels with recursion. Michael
Parentknot? I'm unfamiliar with that term. It would be helpful if you shared your XML process code and a sample dataset. Follow the instructions on the right side of the page for sharing your XML process code
@michael The Read XML operator has an Import Wizard that will guide you through the various levels to get to your data. Did you try that?
