Hi, I work with an XML-File. I understand that I use the operator Read XML. I don't know how to convert the document without losing the different structure levels with recursion. Michael
@michael The Read XML operator has an Import Wizard that will guide you through the various levels to get to your data. Did you try that?
Hi Thomas,
Thanks a lot.
Michael
Parentknot? I'm unfamiliar with that term. It would be helpful if you shared your XML process code and a sample dataset. Follow the instructions on the right side of the page for sharing your XML process code
hmmm... maybe "parentknot" is root node?
Scott
