Unable to generate Spot weld connection between Solid elements
Altair Forum User
Altair Forum User
Altair Employee
edited June 2021 in Community Q&A
Hello Everyone,
I am trying to establish spot weld between Solid Hexa8N elements. I have tried to use 'plot', 'Type 2 spring' and 'HC Hexa' type. But in all the cases I am having following issues:
1) Type (Plot):   Simulation ran but solid elements were not connected
2) Type [Spring (Type 2)]:  Solver not able to identify the surface to create a spring elements.
3) Type HC Hexa: Contact interface defined by solver itself is not correct.
Apart from aforementioned problem I also want to give the max tensile strength of spot weld as as 40% of base material.
Thanks in advance.
Nitin Jain
Welcome!
Answers
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited February 2019
    Hi
    Can you please share your model.
    You can use the secure drop box link https://ftin.india.altair.com:8443/filedrop/~Ma3TaE
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hello @Pranav Hari,
    I have uploaded the file on the shared link.
    But I have deleted some parts and Boundary conditions.
    Please assign boundary condition as per your convenience.
    Regards
    Nitin Jain
  • Pranav Hari
    Hi Nitin Jain
    I will check and update you.
  • Pranav Hari
    Hi Nitin Jain
    The recommended element types in Radioss for spot weld creation are shell element.
    Surface 1 and 2 for each solid spotweld should always connect with a shell element. If one surface of one solid spotweld is not connected with a shell element,
    then the stiffness will not be computed correctly and an error may occur
    Since you are having solid elements you have to create a shell coat and then connect using spots.
    There are three different ways of modeling spotweld:
    Node Connect
    Spring (/PROP/TYPE13) Connect
    Solid Connect
    When you create a spot weld using type 2 spring,  by default you will get the (TYPE13 spring property + TYPE2 contact).
    In your case since you have to define max tensile strength of spot weld as 40% of the base material, then I recommend you use the solid connect method.
    Here you can specify separate failure criteria.
    This is explained in detail in the Radioss help documentation. Please have a look
    Also, have a look at the Radioss example on solid spot weld creation.
    I have shared the 2 example deck files, which is modeled using default spring contact and also solid connect. Check that too.
  • Simon Križnik
    Simon Križnik Altair Community Member
    Contact surfaces can also be used.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2019
    Thanks @Pranav Hari and @Ivan,
    I think making surface and then spot weld is time consuming process.
    Moreover I request you to please teach me, if I connect the extracted surface with connector: then solids will be connected as well or it will connect only extracted surfaces.
    Right now, I am trying to make the Seam weld connections (Hexa Tapered T type) but I am getting the distorted elements:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.48a899a842dc11bc3d428928b40074ac.png
    I am avoiding edge nodes for better results. But still some elements are not as desired.
    Regards
    Nitin Jain
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2019
    Hello everyone,
    Does someone know how to solve the above mentioned problem??
    Thanks in advance.
    Regards
    Nitin Jain
  • tuan trinh
    tuan trinh Altair Community Member
    edited June 2021
    hi you
    i had refered the document, so i never make stiffness of spring, because the result also flying
    pelase show me
    thanks
Welcome!
Welcome!
