🎉Community Raffle - Win $25
Join and Win
Keras extention problem
User: "Tigychen"
New Altair Community Member
Updated by Jocelyn
Hi all,
I installed rapidminer in Ubuntu 14. I test python scripting and keras in rapidminer and it say python 3.4.3 is detected (as expected).
Then, I run the examples of keras extension. The script stoped abnormally, the log message is as below:
It seems tha the problem is that graphviz and pydot cannot be imported. However, I tried to import both of them in python and successeeded
Dec 8, 2017 4:00:14 PM INFO:
Dec 8, 2017 4:00:14 PM INFO: 32/135 [======>.......................] - ETA: 0s - loss: 0.5211
Dec 8, 2017 4:00:14 PM INFO: 135/135 [==============================] - 0s - loss: 0.6655
Dec 8, 2017 4:00:14 PM INFO: Epoch 127/128
Dec 8, 2017 4:00:14 PM INFO: 32/135 [======>.......................] - ETA: 0s - loss: 0.5119
Dec 8, 2017 4:00:14 PM INFO: 135/135 [==============================] - 0s - loss: 0.6613
Dec 8, 2017 4:00:14 PM INFO: Epoch 128/128
Dec 8, 2017 4:00:14 PM INFO: 32/135 [======>.......................] - ETA: 0s - loss: 0.5030
Dec 8, 2017 4:00:14 PM INFO: 135/135 [==============================] - 0s - loss: 0.6572
Dec 8, 2017 4:00:14 PM INFO: Couldn't import graphviz or pydot. Model will not be visualised.
Dec 8, 2017 4:00:15 PM SEVERE: Process failed: Script terminated abnormally.
Dec 8, 2017 4:00:15 PM SEVERE: Here:
Dec 8, 2017 4:00:15 PM SEVERE: Process[1] (Process)
Dec 8, 2017 4:00:15 PM SEVERE: subprocess 'Main Process'
Dec 8, 2017 4:00:15 PM SEVERE: +- Retrieve Iris[1] (Retrieve)
Dec 8, 2017 4:00:15 PM SEVERE: +- Split Data[1] (Split Data)
Dec 8, 2017 4:00:15 PM SEVERE: +- Keras Model[1] (Keras Model)
Dec 8, 2017 4:00:15 PM SEVERE: subprocess 'Executed Process'
Dec 8, 2017 4:00:15 PM SEVERE: | +- Add Core Layer[1] (Add Core Layer)
Dec 8, 2017 4:00:15 PM SEVERE: ==> | +- Add Core Layer (2)[1] (Add Core Layer)
Dec 8, 2017 4:00:15 PM SEVERE: +- Apply Keras Model[0] (Apply Keras Model)
1 - 1 of 11
    User: "Andrew"
    There is an extra component that needs to be installed.
    From the python graphviz installation instructions.
    To render the generated DOT source code, you also need to install Graphviz (download page).
    Make sure that the directory containing the dot executable is on your systems’ path.
    The download link is Download link.
