1 - 7 of
71
The middle node of an RBE2 is the independent node or the master node (Reference node) and connected nodes are slave or following nodes or Dependent nodes.
Dependents nodes cannot depend on other other rigid element or restriction. Restricting these node will end up with such error.
Hi @reiji
Constraining Dependent node of RBE2 is a violation.
Please recheck your model and remove constraints on dependent nodes of RBE2
