1 - 5 of
51
Thanks for the reply. With the configuration you suggested I get a 'label is missing' errror.
What I'd like to do is create correlations - and then isolate the variables that are highly correlated.
I'm following this youtube video and attempting to re-create this process flow
Hi Ally,
Would you mind sharing the dataset you are trying to analyze? The issue may be specific to the dataset.
Attached is the similar process that I have built with a sample dataset for your reference. Also here is the instruction on How to Import a repository in RapidMiner
Cheers
Use the operator Weight by Correlation instead of the correlation matrix.
Take a look at the attached process.
