Shape Memory Alloy
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi again ;
i want to use a shape memory alloy material  ( Ni-Ti for exemple) in RADIOSS
i need your help please
Thanks
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    The best is to use /MAT/LAW65 in Radioss. It’s nonlinear elastic with hystheresis, strain rate dependent, you may also define a plastic region if needed. It is only compatible with shell elements.
    There is also a LAW71, specially developed for NItinol with shape memory, but this one is not very stable actually and I would not recommend it.Hence the good choice is Law65 and I would like to add that law71 is Linear elastic before reaching the yld stress transformation.
    Regards
    Rahul R
    Altair Employee
    OP
    ok @Rahul R i will do it
    Do you have a property of one SMA material??
    thanks
    Altair Employee
    OP
    Hi Fily,
    LAW 65 is compatible with shell elements. So you may have to use TYPE1 property in RADIOSS.
