🎉Community Raffle - Win $25
Join and Win
Error # 4001
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am working on Hypermesh Bulk Data. Analysis type is Non-linear Implicit (NLGEOM). I received following Error message.
'*** ERROR # 4001 ***  Running RADIOSS Strater, 1 ERROR and 0 WARNINGs have been detected.
 *** PROGRAM STOPPED : FATAL ERROR(s) ENCOUNTERED. '
What can I do to overcome this error ?
Any suggestions ?
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    Is this all abour error?
    do you see any starter error ID below this error message?
    In your working directory you should see a file <filename>.0000.out file. Open that file and check for error message and please post them here.
    Altair Employee
    OP
    Hi,
    I have enclosed the Image file of error Messages which i get in .out file. So, how can I solve this issue now?
    FYI,
    I am working on 3 Point bending test of Sandwich Panel. I have made the 3D model & mesh in RADIOSS Bulk Data and not by using laminates. I have defined contact Interfaces with NORM & FREEZE constraints. And Analysis type is NLGEOM.
    <?xml version="1.0" encoding="UTF-8"?>post-32050-0-80209500-1403779374_thumb.p
    Altair Employee
    OP
    check the interface u have created....click review to see whether they are updated or not...and pls see the Gapmin u've specified
