Error # 4001
Hi,
I am working on Hypermesh Bulk Data. Analysis type is Non-linear Implicit (NLGEOM). I received following Error message.
'*** ERROR # 4001 *** Running RADIOSS Strater, 1 ERROR and 0 WARNINGs have been detected.
*** PROGRAM STOPPED : FATAL ERROR(s) ENCOUNTERED. '
What can I do to overcome this error ?
Any suggestions ?
1 - 3 of
31
Hi,
I have enclosed the Image file of error Messages which i get in .out file. So, how can I solve this issue now?
FYI,
I am working on 3 Point bending test of Sandwich Panel. I have made the 3D model & mesh in RADIOSS Bulk Data and not by using laminates. I have defined contact Interfaces with NORM & FREEZE constraints. And Analysis type is NLGEOM.
Hi,
Is this all abour error?
do you see any starter error ID below this error message?
In your working directory you should see a file <filename>.0000.out file. Open that file and check for error message and please post them here.
