Altair RISE
Nominate Yourself Now!
s&p-500-regression -> java.lang.NullPointerException
User: "werbungsbunker"
New Altair Community Member
Updated by Jocelyn
I ran the s&p-500-regression example without modification and I got
Oct 27, 2017 1:56:12 PM INFO: No filename given for result file, using stdout for logging results!
Oct 27, 2017 1:56:12 PM INFO: Process //Keras Samples/sp_500_regression/s&p-500-regression starts
Oct 27, 2017 1:56:12 PM SEVERE: Process failed: operator cannot be executed. Check the log messages...
Oct 27, 2017 1:56:12 PM SEVERE: Here:
Oct 27, 2017 1:56:12 PM SEVERE: Process[1] (Process)
Oct 27, 2017 1:56:12 PM SEVERE: subprocess 'Main Process'
Oct 27, 2017 1:56:12 PM SEVERE: +- Retrieve s&p-500-data[1] (Retrieve)
Oct 27, 2017 1:56:12 PM SEVERE: +- Select Attributes[1] (Select Attributes)
Oct 27, 2017 1:56:12 PM SEVERE: +- Normalize[1] (Normalize)
Oct 27, 2017 1:56:12 PM SEVERE: +- Windowing[1] (Windowing)
Oct 27, 2017 1:56:12 PM SEVERE: +- Set Role[1] (Set Role)
Oct 27, 2017 1:56:12 PM SEVERE: +- Split Data[1] (Split Data)
Oct 27, 2017 1:56:12 PM SEVERE: +- Keras Model[1] (Keras Model)
Oct 27, 2017 1:56:12 PM SEVERE: subprocess 'Executed Process'
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Convolutional Layer[1] (Add Convolutional Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Pooling Layer[1] (Add Pooling Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Convolutional Layer (2)[1] (Add Convolutional Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Pooling Layer (2)[1] (Add Pooling Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Core Layer[1] (Add Core Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Core Layer (2)[1] (Add Core Layer)
Oct 27, 2017 1:56:12 PM SEVERE: | +- Add Core Layer (3)[1] (Add Core Layer)
Oct 27, 2017 1:56:12 PM SEVERE: ==> | +- Add Core Layer (4)[1] (Add Core Layer)
Oct 27, 2017 1:56:12 PM SEVERE: +- Apply Keras Model[0] (Apply Keras Model)
Oct 27, 2017 1:56:12 PM SEVERE: java.lang.NullPointerException
