RapidMiner Server INFO: No filename given for result file, using stdout for logging results!
thapli_64
thapli_64 New Altair Community Member
edited November 2024 in Community Q&A
Hi,
I didn't specify any operators in my process to store results but ran it on the server. It ran successfully but the message in the title was in the logfile. My question is, where can I access the results without using store operators? Or do I have to add them to any process run on the server?
Welcome!
Best Answer
  • Edin_Klapic
    Edin_Klapic New Altair Community Member
    Answer ✓
    Hi @thapli_64,
    The results of processes you execute on RapidMiner Server are only stored if you explicitly use a "Store" Operator. It has the same behavior as RapidMiner Studio, i.e. an Repository object is created.
    Unlike in Studio the Repository objects are not stored on disk but in the RapidMiner Server database.
    Best regards,
    Edin
Answers
  • sgenzer
    sgenzer
    Altair Employee
    yes @thapli_64 any results should be stored somewhere.
    Scott
  • thapli_64
    @sgenzer thanks for the reply. Is there a standard place the results are stored to if I didn't specify any store operators? I don't see anything from the web UI I have been using to monitor processes.
  • Edin_Klapic
    Answer ✓
    Hi @thapli_64,
    Best regards,
    Edin
  • thapli_64
    @Edin_Klapic thaks for your response- I figured as much and have been doing it this way. :)
  • Harper
    Harper New Altair Community Member
    The consequences of cycles you execute on RapidMiner Server are possibly put away in the event that you unequivocally utilize a "Store" Operator. It has a similar way of behaving as RapidMiner Studio, for example a Repository object is made.
    Dissimilar to in Studio the Repository objects are not put away on circle but rather in the RapidMiner Server data set.
Welcome!
Welcome!
