Arithmetic Manipulation of Performance Values
Hi all,
I am wondering if there are ways in rapidminer to manipulate performance values and calculate new indices/variables. For example, we are looking to use Harrell's algorithm for calculating optimism to obtain the performance of each of 1000 permutations of a data set. We have processes (attached) to generate the performance metrics for each of the two models described on page 2 of http://support.sas.com/resources/papers/proceedings13/504-2013.pdf, but I am unsure of how to use rapidminer substact and average these values such that we can obtain an optimism score for the performance of each of the permuted samples (process attached second).
Bootstrap process:
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve (2)" width="90" x="45" y="901">
<parameter key="repository_entry" value="//Local Repository/data/classifier_structural_self_report_cf_HC_2.5.16"/>
</operator>
<operator activated="true" class="filter_examples" compatibility="7.6.001" expanded="true" height="103" name="Filter Examples (2)" width="90" x="45" y="1003">
<list key="filters_list">
<parameter key="filters_entry_key" value="ID.does_not_contain.RH"/>
</list>
</operator>
<operator activated="true" class="collect" compatibility="7.6.001" expanded="true" height="68" name="Collect (4)" width="90" x="648" y="748">
<parameter key="unfold" value="true"/>
</operator>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember (4)" width="90" x="849" y="748">
<parameter key="name" value="performance_fSMRI_bs"/>
<parameter key="io_object" value="Collection"/>
</operator>
<operator activated="true" class="collect" compatibility="7.6.001" expanded="true" height="68" name="Collect (2)" width="90" x="715" y="1054">
</operator>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember (2)" width="90" x="849" y="1054">
<parameter key="name" value="performance_fSMRI_bs_o"/>
</operator>
<operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role (4)" width="90" x="179" y="1156">
<parameter key="attribute_name" value="Label"/>
<parameter key="target_role" value="label"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes (4)" width="90" x="246" y="1003">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attributes" value="Label|CC_Anterior|CC_Central|CC_Mid_Anterior|CC_Mid_Posterior|CC_Posterior|Fifth_Ventricle|Fourth_Ventricle|Left_Accumbens_area|Left_Amygdala|Left_Caudate|Left_Cerebellum_Cortex|Left_Cerebellum_White_Matter|Left_Hippocampus|Left_Inf_Lat_Vent|Left_Lateral_Ventricle|Left_Pallidum|Left_Putamen|Left_Thalamus_Proper|Left_VentralDC|Right_Accumbens_area|Right_Amygdala|Right_Caudate|Right_Cerebellum_Cortex|Right_Cerebellum_White_Matter|Right_Hippocampus|Right_Inf_Lat_Vent|Right_Lateral_Ventricle|Right_Pallidum|Right_Putamen|Right_Thalamus_Proper|Right_VentralDC|lh_bankssts_area|lh_bankssts_thickness|lh_bankssts_volume|lh_caudalanteriorcingulate_area|lh_caudalanteriorcingulate_thickness|lh_caudalanteriorcingulate_volume|lh_caudalmiddlefrontal_area|lh_caudalmiddlefrontal_thickness|lh_caudalmiddlefrontal_volume|lh_cuneus_area|lh_cuneus_thickness|lh_cuneus_volume|lh_entorhinal_area|lh_entorhinal_thickness|lh_entorhinal_volume|lh_frontalpole_area|lh_frontalpole_thickness|lh_frontalpole_volume|lh_fusiform_area|lh_fusiform_thickness|lh_fusiform_volume|lh_inferiorparietal_area|lh_inferiorparietal_thickness|lh_inferiorparietal_volume|lh_inferiortemporal_area|lh_inferiortemporal_thickness|lh_inferiortemporal_volume|lh_insula_area|lh_insula_thickness|lh_insula_volume|lh_isthmuscingulate_area|lh_isthmuscingulate_thickness|lh_isthmuscingulate_volume|lh_lateraloccipital_area|lh_lateraloccipital_thickness|lh_lateraloccipital_volume|lh_lateralorbitofrontal_area|lh_lateralorbitofrontal_thickness|lh_lateralorbitofrontal_volume|lh_lingual_area|lh_lingual_thickness|lh_lingual_volume|lh_medialorbitofrontal_area|lh_medialorbitofrontal_thickness|lh_medialorbitofrontal_volume|lh_middletemporal_area|lh_middletemporal_thickness|lh_middletemporal_volume|lh_paracentral_area|lh_paracentral_thickness|lh_paracentral_volume|lh_parahippocampal_area|lh_parahippocampal_thickness|lh_parahippocampal_volume|lh_parsopercularis_area|lh_parsopercularis_thickness|lh_parsopercularis_volume|lh_parsorbitalis_area|lh_parsorbitalis_thickness|lh_parsorbitalis_volume|lh_parstriangularis_area|lh_parstriangularis_thickness|lh_parstriangularis_volume|lh_pericalcarine_area|lh_pericalcarine_thickness|lh_pericalcarine_volume|lh_postcentral_area|lh_postcentral_thickness|lh_postcentral_volume|lh_posteriorcingulate_area|lh_posteriorcingulate_thickness|lh_posteriorcingulate_volume|lh_precentral_area|lh_precentral_thickness|lh_precentral_volume|lh_precuneus_area|lh_precuneus_thickness|lh_precuneus_volume|lh_rostralanteriorcingulate_area|lh_rostralanteriorcingulate_thickness|lh_rostralanteriorcingulate_volume|lh_rostralmiddlefrontal_area|lh_rostralmiddlefrontal_thickness|lh_rostralmiddlefrontal_volume|lh_superiorfrontal_area|lh_superiorfrontal_thickness|lh_superiorfrontal_volume|lh_superiorparietal_area|lh_superiorparietal_thickness|lh_superiorparietal_volume|lh_superiortemporal_area|lh_superiortemporal_thickness|lh_superiortemporal_volume|lh_supramarginal_area|lh_supramarginal_thickness|lh_supramarginal_volume|lh_temporalpole_area|lh_temporalpole_thickness|lh_temporalpole_volume|lh_transversetemporal_area|lh_transversetemporal_thickness|lh_transversetemporal_volume|rh_bankssts_area|rh_bankssts_thickness|rh_bankssts_volume|rh_caudalanteriorcingulate_area|rh_caudalanteriorcingulate_thickness|rh_caudalanteriorcingulate_volume|rh_caudalmiddlefrontal_area|rh_caudalmiddlefrontal_thickness|rh_caudalmiddlefrontal_volume|rh_cuneus_area|rh_cuneus_thickness|rh_cuneus_volume|rh_entorhinal_area|rh_entorhinal_thickness|rh_entorhinal_volume|rh_frontalpole_area|rh_frontalpole_thickness|rh_frontalpole_volume|rh_fusiform_area|rh_fusiform_thickness|rh_fusiform_volume|rh_inferiorparietal_area|rh_inferiorparietal_thickness|rh_inferiorparietal_volume|rh_inferiortemporal_area|rh_inferiortemporal_thickness|rh_inferiortemporal_volume|rh_insula_area|rh_insula_thickness|rh_insula_volume|rh_isthmuscingulate_area|rh_isthmuscingulate_thickness|rh_isthmuscingulate_volume|rh_lateraloccipital_area|rh_lateraloccipital_thickness|rh_lateraloccipital_volume|rh_lateralorbitofrontal_area|rh_lateralorbitofrontal_thickness|rh_lateralorbitofrontal_volume|rh_lingual_area|rh_lingual_thickness|rh_lingual_volume|rh_medialorbitofrontal_area|rh_medialorbitofrontal_thickness|rh_medialorbitofrontal_volume|rh_middletemporal_area|rh_middletemporal_thickness|rh_middletemporal_volume|rh_paracentral_area|rh_paracentral_thickness|rh_paracentral_volume|rh_parahippocampal_area|rh_parahippocampal_thickness|rh_parahippocampal_volume|rh_parsopercularis_area|rh_parsopercularis_thickness|rh_parsopercularis_volume|rh_parsorbitalis_area|rh_parsorbitalis_thickness|rh_parsorbitalis_volume|rh_parstriangularis_area|rh_parstriangularis_thickness|rh_parstriangularis_volume|rh_pericalcarine_area|rh_pericalcarine_thickness|rh_pericalcarine_volume|rh_postcentral_area|rh_postcentral_thickness|rh_postcentral_volume|rh_posteriorcingulate_area|rh_posteriorcingulate_thickness|rh_posteriorcingulate_volume|rh_precentral_area|rh_precentral_thickness|rh_precentral_volume|rh_precuneus_area|rh_precuneus_thickness|rh_precuneus_volume|rh_rostralanteriorcingulate_area|rh_rostralanteriorcingulate_thickness|rh_rostralanteriorcingulate_volume|rh_rostralmiddlefrontal_area|rh_rostralmiddlefrontal_thickness|rh_rostralmiddlefrontal_volume|rh_superiorfrontal_area|rh_superiorfrontal_thickness|rh_superiorfrontal_volume|rh_superiorparietal_area|rh_superiorparietal_thickness|rh_superiorparietal_volume|rh_superiortemporal_area|rh_superiortemporal_thickness|rh_superiortemporal_volume|rh_supramarginal_area|rh_supramarginal_thickness|rh_supramarginal_volume|rh_temporalpole_area|rh_temporalpole_thickness|rh_temporalpole_volume|rh_transversetemporal_area|rh_transversetemporal_thickness|rh_transversetemporal_volume"/>
</operator>
<operator activated="true" class="sample_bootstrapping" compatibility="7.6.001" expanded="true" height="82" name="Sample (Bootstrapping)" width="90" x="380" y="901">
<parameter key="sample" value="absolute"/>
<parameter key="sample_size" value="6600"/>
</operator>
<operator activated="true" class="shuffle" compatibility="7.6.001" expanded="true" height="82" name="Shuffle" width="90" x="514" y="1003"/>
<operator activated="true" class="loop_batches" compatibility="7.6.001" expanded="true" height="68" name="Loop Batches" width="90" x="648" y="850">
<parameter key="batch_size" value="33"/>
<operator activated="true" class="handle_exception" compatibility="7.6.001" expanded="true" height="82" name="Handle Exception" width="90" x="246" y="136">
<operator activated="true" class="optimize_parameters_grid" compatibility="7.6.001" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="112" y="136">
<list key="parameters">
<parameter key="SVM_full_SVM.C" value="[.03125;32768;20;logarithmic]"/>
</list>
<operator activated="true" class="normalize" compatibility="7.6.001" expanded="true" height="103" name="Normalize" width="90" x="112" y="85"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.6.001" expanded="true" height="82" name="SVM_full_SVM" width="90" x="246" y="85">
<parameter key="kernel_type" value="linear"/>
<parameter key="C" value="32768.0"/>
<list key="class_weights"/>
</operator>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (6)" width="90" x="447" y="136">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="7.6.001" expanded="true" height="82" name="performance_imaging_bs" width="90" x="715" y="289">
<parameter key="AUC (optimistic)" value="true"/>
<parameter key="AUC" value="true"/>
<parameter key="AUC (pessimistic)" value="true"/>
<parameter key="precision" value="true"/>
<parameter key="recall" value="true"/>
<parameter key="sensitivity" value="true"/>
<parameter key="specificity" value="true"/>
<parameter key="positive_predictive_value" value="true"/>
<parameter key="negative_predictive_value" value="true"/>
</operator>
<connect from_port="input 1" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="SVM_full_SVM" to_port="training set"/>
<connect from_op="SVM_full_SVM" from_port="model" to_op="Apply Model (6)" to_port="model"/>
<connect from_op="SVM_full_SVM" from_port="exampleSet" to_op="Apply Model (6)" to_port="unlabelled data"/>
<connect from_op="Apply Model (6)" from_port="labelled data" to_op="performance_imaging_bs" to_port="labelled data"/>
<connect from_op="Apply Model (6)" from_port="model" to_port="result 1"/>
<connect from_op="performance_imaging_bs" from_port="performance" to_port="performance"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
</operator>
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall (3)" width="90" x="380" y="187">
</operator>
<operator activated="true" class="collect" compatibility="7.6.001" expanded="true" height="103" name="Collect (3)" width="90" x="514" y="34">
</operator>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember (3)" width="90" x="648" y="136">
</operator>
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve (3)" width="90" x="45" y="442">
</operator>
<operator activated="true" class="filter_examples" compatibility="7.6.001" expanded="true" height="103" name="Filter Examples (3)" width="90" x="45" y="595">
</list>
</operator>
<operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role (5)" width="90" x="112" y="748">
</operator>
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall (5)" width="90" x="179" y="901">
</operator>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="246" y="595">
</operator>
<operator activated="true" class="normalize" compatibility="7.6.001" expanded="true" height="103" name="Normalize (6)" width="90" x="380" y="646"/>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (5)" width="90" x="447" y="493">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="7.6.001" expanded="true" height="82" name="performance_imaging_bs_o" width="90" x="581" y="442">
</operator>
<operator activated="true" class="collect" compatibility="7.6.001" expanded="true" height="103" name="Collect (5)" width="90" x="514" y="850">
</operator>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember (5)" width="90" x="648" y="748">
</operator>
<connect from_port="in 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_op="Collect (3)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_op="Apply Model (5)" to_port="model"/>
<connect from_op="Recall (3)" from_port="result" to_op="Collect (3)" to_port="input 2"/>
<connect from_op="Collect (3)" from_port="collection" to_op="Remember (3)" to_port="store"/>
<connect from_op="Retrieve (3)" from_port="output" to_op="Filter Examples (3)" to_port="example set input"/>
<connect from_op="Filter Examples (3)" from_port="example set output" to_op="Set Role (5)" to_port="example set input"/>
<connect from_op="Set Role (5)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Recall (5)" from_port="result" to_op="Collect (5)" to_port="input 2"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Normalize (6)" to_port="example set input"/>
<connect from_op="Normalize (6)" from_port="example set output" to_op="Apply Model (5)" to_port="unlabelled data"/>
<connect from_op="Apply Model (5)" from_port="labelled data" to_op="performance_imaging_bs_o" to_port="labelled data"/>
<connect from_op="performance_imaging_bs_o" from_port="performance" to_op="Collect (5)" to_port="input 1"/>
<connect from_op="Collect (5)" from_port="collection" to_op="Remember (5)" to_port="store"/>
<portSpacing port="source_in 1" spacing="0"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 1" spacing="0"/>
<portSpacing port="sink_out 2" spacing="0"/>
</process>
<operator activated="true" class="print_to_console" compatibility="7.6.001" expanded="true" height="82" name="Print to Console" width="90" x="112" y="136">
<parameter key="log_value" value="ERROR Imaging"/>
</operator>
<connect from_port="in 1" to_op="Print to Console" to_port="through 1"/>
<connect from_op="Print to Console" from_port="through 1" to_port="out 1"/>
</process>
</operator>
<connect from_port="exampleSet" to_op="Handle Exception" to_port="in 1"/>
<portSpacing port="source_exampleSet" spacing="0"/>
</process>
</operator>
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall (4)" width="90" x="983" y="850">
</operator>
<operator activated="true" class="write_as_text" compatibility="7.6.001" expanded="true" height="82" name="Write as Text" width="90" x="1117" y="850">
<parameter key="result_file" value="/Users/lsevel/Desktop/fSMRI_performance_bs.txt"/>
</operator>
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall (2)" width="90" x="983" y="1156">
</operator>
<operator activated="true" class="write_as_text" compatibility="7.6.001" expanded="true" height="82" name="Write as Text (2)" width="90" x="1117" y="1207">
<parameter key="result_file" value="/Users/lsevel/Desktop/fSMRI_performance_bs_o.txt"/>
</operator>
<connect from_op="Retrieve (2)" from_port="output" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Set Role (4)" to_port="example set input"/>
<connect from_op="Collect (4)" from_port="collection" to_op="Remember (4)" to_port="store"/>
<connect from_op="Collect (2)" from_port="collection" to_op="Remember (2)" to_port="store"/>
<connect from_op="Set Role (4)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/>
<connect from_op="Select Attributes (4)" from_port="example set output" to_op="Sample (Bootstrapping)" to_port="example set input"/>
<connect from_op="Sample (Bootstrapping)" from_port="example set output" to_op="Shuffle" to_port="example set input"/>
<connect from_op="Shuffle" from_port="example set output" to_op="Loop Batches" to_port="example set"/>
<connect from_op="Recall (4)" from_port="result" to_op="Write as Text" to_port="input 1"/>
<connect from_op="Recall (2)" from_port="result" to_op="Write as Text (2)" to_port="input 1"/>
<description align="center" color="yellow" colored="false" height="182" resized="false" width="180" x="1085" y="177">aSMRI--a priori SMRI features<br>fSMRI--full set of SMRI features<br>SR--self-report<br/>bs=model fit on bootstrapped samples<br/>bs_o--bootstrap generated model fit on original sample</description>
</process>
</operator>
</process>
Permutation process:
<context>
<input/>
<output/>
<macros/>
</context>
<parameter key="repository_entry" value="../../data/_plos_one_permuted_cfs_hc"/>
</operator>
</list>
</operator>
</operator>
<parameter key="name" value="performance_fSMRI_perm"/>
</operator>
</operator>
<parameter key="name" value="fSMRI_perm_param"/>
</operator>
</operator>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes (4)" width="90" x="313" y="901">
</operator>
<operator activated="true" class="loop_clusters" compatibility="7.6.001" expanded="true" height="82" name="Loop Clusters" width="90" x="581" y="901">
<operator activated="true" class="normalize" compatibility="7.6.001" expanded="true" height="103" name="Normalize" width="90" x="45" y="340"/>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="7.6.001" expanded="true" height="82" name="SVM_apriori_SVM" width="90" x="179" y="340">
<parameter key="C" value="0.03125"/>
</operator>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (6)" width="90" x="313" y="340">
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="7.6.001" expanded="true" height="82" name="performance_imaging_bs" width="90" x="514" y="289">
</operator>
</operator>
</operator>
</operator>
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall (5)" width="90" x="380" y="901">
</operator>
<operator activated="true" class="collect" compatibility="7.6.001" expanded="true" height="103" name="Collect (5)" width="90" x="514" y="646">
</operator>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember (5)" width="90" x="648" y="646">
</operator>
<connect from_port="in 1" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="SVM_apriori_SVM" to_port="training set"/>
<connect from_op="SVM_apriori_SVM" from_port="model" to_op="Apply Model (6)" to_port="model"/>
<connect from_op="SVM_apriori_SVM" from_port="exampleSet" to_op="Apply Model (6)" to_port="unlabelled data"/>
<connect from_op="Apply Model (6)" from_port="model" to_op="Collect (5)" to_port="input 1"/>
<connect from_op="performance_imaging_bs" from_port="performance" to_op="Collect (3)" to_port="input 1"/>
</process>
</operator>
</process>
</operator>
<connect from_port="cluster subset" to_op="Handle Exception" to_port="in 1"/>
<portSpacing port="source_cluster subset" spacing="0"/>
</process>
</operator>
</operator>
<parameter key="result_file" value="/Users/lsevel/Desktop/fSMRI_performance_perm.txt"/>
</operator>
</operator>
<parameter key="result_file" value="/Users/lsevel/Desktop/fSMRI_perm_param.txt"/>
</operator>
<connect from_op="Select Attributes (4)" from_port="example set output" to_op="Loop Clusters" to_port="example set"/>
</process>
</operator>
</process>
Is this possible in rapidminer?
Thank you all,
1 - 1 of
11
Hello @lsevel - that's an interesting question. Generally I use one of the following operators depending on what is needed:
Aggregate
Generate Aggregation
Generate Attributes (and using the function generator)
Does this help? I will leave it to @IngoRM or @TobiasMalbrecht who wrote the Logistic Regression Optimization code to chime in on the specifics of implementing Harrell's Optimism.
Scott
Scott
