order of class names in confusion matrix
Hello fellow data analysts,
I was wondering if I can change the order of classes in a confusion matrix. For instance, I have five classes, which I want them to appear in conf matrix in the following order: Good, Satisfactory, Fair, Poor, Very Poor (i e their order matters). But now they are sorted this way: Very Poor, Fair, Satisfactory, Poor, Good. Based on what rationale rapidminer sorts the labels like this? Obviously, it is not alphabetical. PS the type of label attribute is "polynomial."
Thank you in advance,
You could rename your categories with an integer preceding the actual name reflecting the order that you want, and then use @mschmitz 's sorting suggestion after that. This is the only reliable way I have found for getting attributes with many nominal categories to appear in the order that I want in using RapidMiner. It's a bit frustrating to do it that way but it will work.
Telcontar120 and @mschmitz. Seems a bit frustrating, but I will try it for now. Best,
Could you please elaborate on the idea of "Sort + Append with only one input"? I did not get it.
Thanks,
Thanks,
attached is an example. It's ordering the classes alphabetically or inverse alphabetically.
Cheers,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve Sonar" width="90" x="112" y="136">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
</operator>
<operator activated="true" class="sort" compatibility="8.0.001" expanded="true" height="82" name="Sort" width="90" x="246" y="136">
<parameter key="attribute_name" value="class"/>
<parameter key="sorting_direction" value="decreasing"/>
</operator>
<operator activated="true" class="append" compatibility="8.0.001" expanded="true" height="82" name="Append" width="90" x="380" y="136"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.0.001" expanded="true" height="145" name="Validation" width="90" x="514" y="136">
<parameter key="sampling_type" value="stratified sampling"/>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.0.001" expanded="true" height="82" name="Decision Tree" width="90" x="45" y="34"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
<description align="left" color="green" colored="true" height="80" resized="true" width="248" x="37" y="137">In the training phase, a model is built on the current training data set. (90 % of data by default, 10 times)</description>
</process>
<operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
</operator>
<operator activated="true" class="performance" compatibility="8.0.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance" from_port="example set" to_port="test set results"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
<description align="left" color="blue" colored="true" height="103" resized="true" width="315" x="38" y="137">The model created in the Training step is applied to the current test set (10 %).<br/>The performance is evaluated and sent to the operator results.</description>
</process>
<description align="center" color="transparent" colored="false" width="126">A cross-validation evaluating a decision tree model.</description>
</operator>
<connect from_op="Retrieve Sonar" from_port="output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_op="Validation" to_port="example set"/>
<connect from_op="Validation" from_port="performance 1" to_port="result 1"/>
</process>
</operator>
</process>
Hi,
RapidMiner maps Polynomial data types to integers in the background. This is in many cases not noteworthy for a user. I would argue in your case it might be. Your case is maybe a bit different.
One could try to do Sort + Append with only one input. This usually forces a remapping of all indices. But that would yield to an alphabetically sorted confusion matrix.
Best.
Martin
