🎉Community Raffle - Win $25
Join and Win
Cannot connect to rapid miner-server
maedUser: "maed"
New Altair Community Member
Updated by Jocelyn
Hello
I set up RM server in an Amazon instance and I can connect to it through the web or within the RM Studio normally at home.
I tried to connect it to another RM Studio user I have at work but it pops an error regarding a license issue. Attached the error.
Please help me understand if it's a license or connection issue (firewall at work).
Thank you!
1 - 5 of 51
    hello @maed - that is very hard to debug without knowing more about the configuration.   Firewall could be the issue if your AWS IAM is not set correctly - you could try pinging the server from work and see if you get a response.  Also make sure you have exactly the same version of RapidMiner at work as on the server.  They must be the same.
    Scott
    maedUser: "maed"
    OP
    Hi @sgenzer. Thanks for you answer.
    The RapidMiner Server service starts and then immediately stops. It doesnt stay up even after several attempts.
    I just don't understand where the problem is.
    Any help is more than welcome.
    Thanks
    hello @maed - I'm sorry you're having this trouble  It's hard to figure out sometimes with cloud servers where the issue is.  Just curious - what size instance did you launch?  You need a bare minimum of 8 GB to run RM Server.
    Scott
    maedUser: "maed"
    OP
    Hi @sgenzer
    Actually I have the free tier of AWS which consists of a machine with 1GB of RAM and 30GB of storage. I used for the past 10 months with RM 7.5 and it worked. I am having problems since I upgraded to 7.6.
    Probably you're right about the memory needed :).
    Thanks for your answers
    Wow that is very surprising that it was running with 1GB of RAM.  I usually run with a t2.large instance.
    Scott
