Why Some Control Cards in Radioss Profile are not Displayed ?
yeshwanth
yeshwanth Altair Community Member
edited September 2021 in Community Q&A
When i imported a 0000.rad starter file into radioss profile,I'm not able to see some of the control cards like Run,Anim DT cards.I'm able to see only 4 cards in radioss profile.But when i imported the same file in other pc,im able to see 15 control cards.But in my pc,im able to see only 4 control cards,i don't know why,I reinstalled the hypermesh student edition multiple times but i was facing the same issue,I also requested and downloaded the setup file from altair blog multiple times,but still i was facing the same issue,can anyone please help me with this and give some suggestions and solutions to get rid off this control cards issue.
Thanks & Regards,
Yeshwanth N.
Answers
  • Rodrigo Merigo_22161
    Altair Employee
    Hi,
    Please make sure you are using the solver browser in HyperMesh to View/Edit the solver cards. Also, check if the version of the files are compatible with the software version. If the cards appear in the file (when you open it as text), you should be able to see it in HyperMesh, when selected the Radioss profile.
    One more thing: Please note that engine cards are stored in the 0001.rad file, not the 0000.rad. Being so, the control cards will only be imported in HM if both 0000 and 0001.rad files are in the same directory and with the same name.
    Thanks.
Welcome!
Welcome!
