file type for simulation
hellow , i have a question;
I have to make a fluid dynamics simulation to a formula sae car, but for the machine files I have a file solidworks 'assembly'.
if I create a file .iges this is very heavy because I have a lot of machine components, if i create a file .stl this export only lines and create complex surface in hypermesh is not simple.
How can I fix the problem ?
I have to change the file type?
can i use some program that allows me to make my geometry suited to a simulation ?
Thanks /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20'>
