🎉Community Raffle - Win $25
Join and Win
Filtering with a looped parameter
User: "edinsda2"
New Altair Community Member
Updated by Jocelyn
Hi All,
I have a data set with dates ranging from the beginning to the end of 2016. I am creating a forecasting model and I want to iterate through the data set multiple times, the first time removing the last 6 months, the second time removing the last 5 months, then removing the last 4 months etc.
I am currently trying to so this using a loop parameters operation and trying to adjust the filter, however I can either not get the syntax right or need a different approach.
Could someone please tell me the exact options to select in the loop parameters tool or a better method
Thank you in advance
1 - 4 of 41
    User: "FBT"
    I may not fully understand the exact thing you would like to achieve, but I would probably take a look at the Macro operators (Set Macro or Extract Macro) and use the defined macros as loop parameters. If your data is not sensitive, or, if you can make up fake data with the same structure and post it here, I can take a closer look.
    Dear Edinsda,
    Do you want to do this for validation purposes? In this case Sliding Window Validation might be the right operator.
    Otherwise you can do it with a combination of Loop Parameters and Filter Examples Range (or Filter Examples). Attached is a process which shows it.
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.5.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="generate_data" compatibility="7.5.003" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"/>
    <operator activated="true" class="extract_macro" compatibility="7.5.003" expanded="true" height="68" name="Extract Macro" width="90" x="380" y="34">
    <parameter key="macro" value="numberOfExamples"/>
    <list key="additional_macros"/>
    </operator>
    <operator activated="true" class="loop_parameters" compatibility="7.5.003" expanded="true" height="82" name="Loop Parameters" width="90" x="514" y="34">
    <list key="parameters">
    <parameter key="Filter Example Range.first_example" value="[1.0;50;3;linear]"/>
    </list>
    <operator activated="true" class="filter_example_range" compatibility="7.5.003" expanded="true" height="82" name="Filter Example Range" width="90" x="112" y="34">
    <parameter key="first_example" value="50"/>
    <parameter key="last_example" value="%{numberOfExamples}"/>
    </operator>
    <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.5.000" expanded="true" height="103" name="Generalized Linear Model" width="90" x="782" y="34">
    <list key="beta_constraints"/>
    <list key="expert_parameters"/>
    </operator>
    <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/>
    <connect from_op="Filter Example Range" from_port="example set output" to_op="Generalized Linear Model" to_port="training set"/>
    <connect from_op="Generalized Linear Model" from_port="model" to_port="result 1"/>
    <portSpacing port="source_input 2" spacing="0"/>
    <portSpacing port="sink_performance" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Generate Data" from_port="output" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Extract Macro" from_port="example set" to_op="Loop Parameters" to_port="input 1"/>
    <connect from_op="Loop Parameters" from_port="result 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
    User: "edinsda2"
    OP
    Thank you both for your response.
    Here is an example XML for what I am trying to achive. Where the filter value is set to 1, I want to loop through setting it to 1, 2, 3, 4, 5, 6, 7, 8 and 9.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
    <operator activated="true" class="generate_data" compatibility="7.5.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"/>
    <operator activated="true" class="extract_macro" compatibility="7.5.001" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34">
    </operator>
    <operator activated="true" class="loop_parameters" compatibility="7.5.001" expanded="true" height="82" name="Loop Parameters" width="90" x="380" y="34">
    </list>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="7.5.001" expanded="true" height="103" name="Filter Examples" width="90" x="246" y="85">
    <list key="filters_list">
    <parameter key="filters_entry_key" value="att1.gt.1"/>
    </list>
    </operator>
    <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/>
    </process>
    </operator>
    </process>
    </operator>
    </process>
    The biggest issue is that I don't know what to select in loop parameters, see the image below.
    I can't get the parameter string or parameter expression to work and I don't know what the others do.
    Thanks again
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Dear Edindsa,
    i would propose to do this with a standard Loop operator. It gives you a macro (e.g. process variable) with the current iteration number. We can use this to generate ourselves a macro with the filter value and use it in the filter. The expressions we use for this can be very sophisticated.
    An example is attached.
    Best,
    Martin
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="extract_macro" compatibility="7.5.003" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34">
    </operator>
    <operator activated="true" class="concurrency:loop" compatibility="7.5.003" expanded="true" height="82" name="Loop" width="90" x="514" y="34">
    <operator activated="true" class="generate_macro" compatibility="7.5.003" expanded="true" height="82" name="Generate Macro (2)" width="90" x="179" y="34">
    <list key="function_descriptions">
    <parameter key="filterValue" value="eval(%{iteration})"/>
    </list>
    <description align="center" color="transparent" colored="false" width="126">We can do more complex things here</description>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="7.5.003" expanded="true" height="103" name="Filter Examples (2)" width="90" x="447" y="34">
    <parameter key="filters_entry_key" value="att1.gt.%{filterValue}"/>
    </list>
    </operator>
    <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.5.000" expanded="true" height="103" name="Generalized Linear Model (2)" width="90" x="648" y="34">
    </operator>
    <connect from_port="input 1" to_op="Generate Macro (2)" to_port="through 1"/>
    <connect from_op="Generate Macro (2)" from_port="through 1" to_op="Filter Examples (2)" to_port="example set input"/>
    <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Generalized Linear Model (2)" to_port="training set"/>
    <connect from_op="Generalized Linear Model (2)" from_port="model" to_port="output 1"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    </operator>
    <operator activated="false" class="loop_parameters" compatibility="7.5.003" expanded="true" height="82" name="Loop Parameters" width="90" x="514" y="289">
    </list>
    <operator activated="true" class="generate_macro" compatibility="7.5.003" expanded="true" height="82" name="Generate Macro" width="90" x="45" y="34">
    <list key="function_descriptions"/>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="7.5.003" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="34">
    </list>
    </operator>
    </operator>
    <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/>
    <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Generalized Linear Model" to_port="training set"/>
    </process>
    </operator>
    <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/>
    <connect from_op="Loop" from_port="output 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
