Altair RISE
Nominate Yourself Now!
Decsion Tree Weight Base with different Criterion
User: "Kian"
New Altair Community Member
Updated by Jocelyn
How i can do Decision tree weight base with different criterion (like gain_ratio,information_gain, gini_index, accuracy) with RapidMiner software.
in Decision tree (weight_base) operator, there is not this option.
Thanks
1 - 10 of 101
    User: "Thomas_Ott"
    To help me understand better, are you referring to feeding weighted examples into the Decision Tree operator? If yes, you can do that with something like a Weight by Stratification operator and feed in the data into the Decision Tree operator. From there you can selec the gain_ration, information_gain, etc.
    If you want to weigh attributes by gain_ratio, etc. You can use the Weight by Information Gain, Weight by Gini, etc operators.
    User: "Kian"
    OP
    Thanks for reply, i think i should explain more.
    I did weighting on my main dataset and create datasets result in several weighitng operator.
    so i have a main dataset and several datast result in weighting operator in this dataset i have important attribute only.
    at second section i want to do deciosion tree weight base with different criterion.
    Example: dataset resultin gain ratio>> dicision tree weight base for examample with accuracy criterion and etc.
    IN Decision Tree operator there are 4 criterion but in Decision Tree weight-base operator there is not this option!
    User: "Thomas_Ott"
    Yes, that is correct. In the Decision Tree operator you can select 4 different criterion. The Weight by <....> operators allow only one scheme of splitting.
    User: "Kian"
    OP
    Are there any solutions?!
    User: "Thomas_Ott"
    You could do something like this. If you need to feed in the weights from one Weight By <...> downstream, use the Weights to Data operator.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.5.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="retrieve" compatibility="7.5.003" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34">
    <parameter key="repository_entry" value="//Samples/data/Iris"/>
    </operator>
    <operator activated="true" class="weight_by_information_gain" compatibility="7.5.003" expanded="true" height="82" name="Weight by Information Gain" width="90" x="179" y="34"/>
    <operator activated="true" class="weight_by_information_gain_ratio" compatibility="7.5.003" expanded="true" height="82" name="Weight by Information Gain Ratio" width="90" x="380" y="85"/>
    <operator activated="true" class="weight_by_gini_index" compatibility="7.5.003" expanded="true" height="82" name="Weight by Gini Index" width="90" x="581" y="187"/>
    <connect from_op="Retrieve Iris" from_port="output" to_op="Weight by Information Gain" to_port="example set"/>
    <connect from_op="Weight by Information Gain" from_port="weights" to_port="result 1"/>
    <connect from_op="Weight by Information Gain" from_port="example set" to_op="Weight by Information Gain Ratio" to_port="example set"/>
    <connect from_op="Weight by Information Gain Ratio" from_port="weights" to_port="result 2"/>
    <connect from_op="Weight by Information Gain Ratio" from_port="example set" to_op="Weight by Gini Index" to_port="example set"/>
    <connect from_op="Weight by Gini Index" from_port="weights" to_port="result 3"/>
    <portSpacing port="sink_result 3" spacing="0"/>
    <portSpacing port="sink_result 4" spacing="0"/>
    </process>
    </operator>
    </process>
    User: "Kian"
    OP
    Thans Dear Thomas for your reply
    for weighting dataset there are solustion by using operatrs, but my problem is doing decision tree weight-base with different criterion!
    my problem is in operator "decision tree weight base" there are not option for 4 criterion (accuracy gini index and etc).
    User: "Thomas_Ott"
    Can you post a process, I'm not clear on what it is you want to do exactly. Thanks.
    User: "Kian"
    OP
    User: "Kian"
    OP
    3.jpg is the process and 2 is subprocess of decision tree, problem is in decision tree weight base operator there is not optopn for criterion.
    User: "Thomas_Ott"
    I see now. I completely forgot about the Decision Treet Weight Based operator. That operator will not let you select the splitting criteria, you have to use one of the Weight By <...> operators inside.
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
    <operator activated="true" class="generate_nominal_data" compatibility="7.5.003" expanded="true" height="68" name="Generate Nominal Data" width="90" x="179" y="34">
    <parameter key="number_of_attributes" value="3"/>
    <parameter key="number_of_values" value="3"/>
    </operator>
    <operator activated="true" class="multiply" compatibility="7.5.003" expanded="true" height="124" name="Multiply" width="90" x="313" y="34"/>
    <operator activated="true" class="decision_tree_weight_based" compatibility="7.5.003" expanded="true" height="68" name="Decision Tree with Gini" width="90" x="648" y="238">
    <parameter key="confidence" value="0.01"/>
    <operator activated="true" class="weight_by_gini_index" compatibility="7.5.003" expanded="true" height="82" name="Weight by Gini Index" width="90" x="482" y="34"/>
    <connect from_port="training set" to_op="Weight by Gini Index" to_port="example set"/>
    <connect from_op="Weight by Gini Index" from_port="weights" to_port="weights"/>
    <portSpacing port="source_training set" spacing="0"/>
    <portSpacing port="sink_weights" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="decision_tree_weight_based" compatibility="7.5.003" expanded="true" height="68" name="Decision Tree with Gain Ratio" width="90" x="648" y="136">
    <operator activated="true" class="weight_by_information_gain_ratio" compatibility="7.5.003" expanded="true" height="82" name="Weight by Information Gain Ratio" width="90" x="482" y="34"/>
    <connect from_port="training set" to_op="Weight by Information Gain Ratio" to_port="example set"/>
    <connect from_op="Weight by Information Gain Ratio" from_port="weights" to_port="weights"/>
    </process>
    </operator>
    <operator activated="true" class="decision_tree_weight_based" compatibility="7.5.003" expanded="true" height="68" name="Decision Tree with Info Gain" width="90" x="648" y="34">
    <operator activated="true" class="weight_by_information_gain" compatibility="7.5.003" expanded="true" height="82" name="Weight by Information Gain" width="90" x="313" y="34"/>
    <connect from_port="training set" to_op="Weight by Information Gain" to_port="example set"/>
    <connect from_op="Weight by Information Gain" from_port="weights" to_port="weights"/>
    </process>
    </operator>
    <connect from_op="Generate Nominal Data" from_port="output" to_op="Multiply" to_port="input"/>
    <connect from_op="Multiply" from_port="output 1" to_op="Decision Tree with Info Gain" to_port="training set"/>
    <connect from_op="Multiply" from_port="output 2" to_op="Decision Tree with Gain Ratio" to_port="training set"/>
    <connect from_op="Multiply" from_port="output 3" to_op="Decision Tree with Gini" to_port="training set"/>
    <connect from_op="Decision Tree with Gini" from_port="model" to_port="result 3"/>
    <connect from_op="Decision Tree with Gain Ratio" from_port="model" to_port="result 2"/>
    <connect from_op="Decision Tree with Info Gain" from_port="model" to_port="result 1"/>
    </process>
    </operator>
    </process>
