Set a the param (k) for the k-NN operator
jems_blint
jems_blint New Altair Community Member
edited November 2024 in Community Q&A
Hi,
I have a k-NN, and i want to set the parameter k dynamically how can i achieve that ?
Thank you !
Answers
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    Use the Optimize Parameters operator
  • Telcontar120
    Telcontar120 New Altair Community Member
    You could use Loop Parameters, see the attached sample process.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.5.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="retrieve" compatibility="7.5.003" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="85">
    <parameter key="repository_entry" value="//Samples/data/Sonar"/>
    </operator>
    <operator activated="true" class="loop_parameters" compatibility="7.5.003" expanded="true" height="103" name="Loop Parameters" width="90" x="246" y="85">
    <list key="parameters">
    <parameter key="Clustering.k" value="[2.0;10;8;linear]"/>
    </list>
    <operator activated="true" class="k_means" compatibility="7.5.003" expanded="true" height="82" name="Clustering" width="90" x="313" y="85">
    <parameter key="k" value="10"/>
    </operator>
    <connect from_port="input 1" to_op="Clustering" to_port="example set"/>
    <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/>
    <connect from_op="Clustering" from_port="clustered set" to_port="result 2"/>
    <portSpacing port="source_input 2" spacing="0"/>
    <portSpacing port="sink_performance" spacing="0"/>
    <portSpacing port="sink_result 3" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Retrieve Sonar" from_port="output" to_op="Loop Parameters" to_port="input 1"/>
    <connect from_op="Loop Parameters" from_port="result 1" to_port="result 1"/>
    <connect from_op="Loop Parameters" from_port="result 2" to_port="result 2"/>
    </process>
    </operator>
    </process>
Welcome!
Welcome!
