🎉Community Raffle - Win $25
Join and Win
Select first n attributes from example set
User: "qwertz2"
New Altair Community Member
Updated by Jocelyn
Dear all,
Is there an efficient way to select first n attributes from an example set? In my process I have reordered the attributes in ascending way. Now I want to proceed with just the first 5 attributes.
I was thinking of several combinations of "select attributes", "work ok subset", "branch", "loop attributes" but none of them worked.
Looking forward to any comments!
Best regards
Sachs
1 - 3 of 31
    Hi,
    i would go for: Filter Examples (remove all), Transpose, Filter Examples Range (Select the atts you want), Transpose, Data to Weights. The result is a weight vector you can apply with Select by Weights to your original data set.
    ~Martin
    User: "qwertz2"
    OP
    Hi Martin,
    Thanks for your help. That's indeed a good approach that could work but unfortunately not in my case. My example set has many many many attributes and just a few examples. Once I transpose the example set I exceed my license of 10.000 examples as there are even more attributes...
    Best regards
    Sachs
    User: "qwertz2"
    OP
    Accepted Answer
    Wonder why I haven't seen this operator before but "remove attribute range" is the operator that solves my problem! It can be combined with "extract macro" to count the number of attributes first.
