How to trim line with spline?
Travis.Designer
Travis.Designer Altair Community Member
edited October 2020 in Community Q&A
Hi
I try to trim line with spline, it not work. I search in website Altair guide, they said 'Note: This tool does not currently work on Splines.'
Do we have other solution?
Best regards
Travis
Answers
  • Mario_21478
    Mario_21478 Altair Community Member
    edited February 2020
    Hello,
    For me it works well with the Curves-> Intersect command.
    If the curves are not in one plane, I have to define the direction of projection using Visual Intersection.
    Best Regards,
    Mario
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.408e61bb177caa96d9d61d3d32c2daaf.png
  • ArjunA_22390
    ArjunA_22390
    Altair Employee
    edited April 2020
    Spline is not currently supported within sketching but you can use intersect curve to get the result you want. Trimming splines will be available in the upcoming release, most likely 20.2 (sep)
Welcome!
Welcome!
