Hi
I try to trim line with spline, it not work. I search in website Altair guide, they said 'Note: This tool does not currently work on Splines.'
Do we have other solution?
Best regards
Travis
For me it works well with the Curves-> Intersect command.
If the curves are not in one plane, I have to define the direction of projection using Visual Intersection.
Best Regards,
Mario
Spline is not currently supported within sketching but you can use intersect curve to get the result you want. Trimming splines will be available in the upcoming release, most likely 20.2 (sep)
